Temperature Tower gcode?
Tim G
(@tim-g)
Is there a gcode for a temperature tower for PETG somewhere?
Posted : 17/09/2020 12:01 am
jsw
 jsw
(@jsw)
RE: Temperature Tower gcode?
Try this one: https://www.prusaprinters.org/prints/4667-all-in-one-temperature-bridging-tower-pla-petg-gco
Posted : 17/09/2020 12:12 am
Tim G
(@tim-g)
Thanks.  Trying to find a good temperature for matterhackers PETG filament.  what they recommend is very different from prusa's "generic PETG".
Posted : 17/09/2020 12:20 am
jsw
 jsw
(@jsw)
When you use those towers, you will get a good idea on what temperatures will give you the least stringing, the best bridging, and the best detail in the peaks.
Posted : 17/09/2020 9:55 am
@jsw
Good suggestion. It's the one I'm using. I remixed it to have the higher temp at the bottom, to avoid clogging: https://www.prusaprinters.org/prints/39810-all-in-one-temperature-and-bridging-tower-high-to-
Posted : 17/09/2020 6:40 pm
Tim G
(@tim-g)
So, I ran the tower.  There was definitely delamination of layers at the lowest temperature.  Some of the bridging looked suspect above that, but overall there was a lot of stringing.  really hard to tell which of the little cones looked better.
Posted : 17/09/2020 6:54 pm
@tim_gallagher
What are your settings? I just accept that I'll see a bit of stringing with PETG that my heat gun can take care off but this looks excessive. Maybe you can upload your 3mf file.
Posted : 17/09/2020 7:01 pm
Tim G
(@tim-g)
I just ran the gcode that @jsw linked to.
This post was modified 5 years ago by Tim G
Posted : 17/09/2020 7:03 pm
Tim G
(@tim-g)
ok, I ran your gcode and got very different results.  Can you tell me what you used for your slicer settings?
Posted : 18/09/2020 6:14 am
@tim_gallagher
Sure. Just go to the Files tab on the model's website, look for Model Files and load temp-tower-petg.3mf into PrusaSlicer. The 3mf file has all the settings.
Posted : 18/09/2020 11:06 am
