					                		Supports on vertical surfaces don&#039;t have any effect - How do I print this? (Printing help)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/supports-on-vertical-surfaces-dont-have-any-effect/</link>
                <lastBuildDate>Thu, 11 Jun 2026 07:16:03 +0000</lastBuildDate>
                        <title>RE: Supports on vertical surfaces don&#039;t have any effect</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/supports-on-vertical-surfaces-dont-have-any-effect/#post-791395</link>
                        <pubDate>Tue, 05 May 2026 14:33:03 +0000</pubDate>
                        <description><![CDATA[I know this is an old post, but your solution above worked for me too. However I noticed you tilted it enough to effect the top layer. This is not necessary. I tilted my detail 0.01 degrees....]]></description>
                        <content:encoded><![CDATA[<p>I know this is an old post, but your solution above worked for me too. However I noticed you tilted it enough to effect the top layer. This is not necessary. I tilted my detail 0.01 degrees. It's such a small amount that you see no layer difference, but it still triggers the supports.<a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/05/fccb496d-screenshot-2026-05-05-103223.jpg"><img class="alignnone size-medium wp-image-186223" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/05/fccb496d-screenshot-2026-05-05-103223-529x500.jpg" alt="" width="529" height="500" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>CaptainTightPants</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/supports-on-vertical-surfaces-dont-have-any-effect/#post-791395</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/supports-on-vertical-surfaces-dont-have-any-effect/#post-688488</link>
                        <pubDate>Sat, 09 Dec 2023 01:56:58 +0000</pubDate>
                        <description><![CDATA[Posted by: @fuchsr Yes, supports in the slicer are really for horizontal (or angled) surfaces, not vertical ones. I have a few tall models, and I modeled breakaway supports into the design. ...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="145735" data-postid="688397" data-mention="fuchsr"><div class="wpforo-post-quote-author"><strong> Posted by: @fuchsr </strong></div><p>Yes, supports in the slicer are really for horizontal (or angled) surfaces, not vertical ones. I have a few tall models, and I modeled breakaway supports into the design. </p><p>But looking at this particular model: you should be good by just adding 6 to 10 mms of a brim to it.</p></blockquote><p>This model was a specific example of a more general issue and yes should be good with a brim.</p><p>The most challenging prints I have done to date on the (bed-slinger) i3 are tall TPU prints that while they stick without problem to the bed, they wobble horrendously as the bed moves.  The problem I see with adding supports to the model is that I have different printers and not all are as precise as the i3.  What gap works for the i3 would result in a firmly stuck support part on another printer with a much larger nozzle.  By using supports in the slicer I don't have to worry about having separate models as I already have separate configurations in Prusaslicer for each printer, tuned so that supports work as intended for each printer.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>MartinV</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/supports-on-vertical-surfaces-dont-have-any-effect/#post-688488</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/supports-on-vertical-surfaces-dont-have-any-effect/#post-688483</link>
                        <pubDate>Sat, 09 Dec 2023 01:44:32 +0000</pubDate>
                        <description><![CDATA[I had a similar issue, and resolved it by adding a surplus hole about 1/3 model height, the support then supported the hole, and braced the model, can you add PART DEPTH hole on the inside o...]]></description>
                        <content:encoded><![CDATA[<blockquote>
<p>I had a similar issue, and resolved it by adding a surplus hole about 1/3 model height, the support then supported the hole, and braced the model, <br />can you add PART DEPTH hole on the inside of the model, so that it is not seen in the final model?</p>
<p>That is one workaround I hadn't considered.  Hmm, in this particular case I could add some styling to the design and add support there.  Or another possibility would be to add a modifier within Prusaslicer - I have recently started using the recycle icon from the shape gallery - and placing that in a strategic place could now server two purposes.  That doesn't even require editing the model.  Then again, using a modifier in Prusaslicer to add a shallow hole also doesn't require editing the model.  Interesting, thank you.</p>
<p>I'll still be glad if one day supports on vertical surfaces do actually produce something.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/supports-on-vertical-surfaces-dont-have-any-effect/#post-688483</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/supports-on-vertical-surfaces-dont-have-any-effect/#post-688397</link>
                        <pubDate>Fri, 08 Dec 2023 17:00:22 +0000</pubDate>
                        <description><![CDATA[Yes, supports in the slicer are really for horizontal (or angled) surfaces, not vertical ones. I have a few tall models, and I modeled breakaway supports into the design. But looking at this...]]></description>
                        <content:encoded><![CDATA[<p>Yes, supports in the slicer are really for horizontal (or angled) surfaces, not vertical ones. I have a few tall models, and I modeled breakaway supports into the design. </p><p>But looking at this particular model: you should be good by just adding 6 to 10 mms of a brim to it.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>FoxRun3D</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/supports-on-vertical-surfaces-dont-have-any-effect/#post-688397</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/supports-on-vertical-surfaces-dont-have-any-effect/#post-688356</link>
                        <pubDate>Fri, 08 Dec 2023 10:38:31 +0000</pubDate>
                        <description><![CDATA[I had a similar issue, and resolved it by adding a surplus hole about 1/3 model height, the support then supported the hole, and braced the model, can you add  PART DEPTH  hole on the inside...]]></description>
                        <content:encoded><![CDATA[<p>I had a similar issue, and resolved it by adding a surplus hole about 1/3 model height, the support then supported the hole, and braced the model, <br />can you add  PART DEPTH  hole on the inside of the model, so that it is not seen in the final model? </p><p>maybe add two holes at 1/3rd height and 2/3rd height for more support<br />regards Joan</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>JoanTabb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/supports-on-vertical-surfaces-dont-have-any-effect/#post-688356</guid>
                        <title>Supports on vertical surfaces don&#039;t have any effect</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/supports-on-vertical-surfaces-dont-have-any-effect/#post-688325</link>
                        <pubDate>Fri, 08 Dec 2023 05:36:03 +0000</pubDate>
                        <description><![CDATA[Hi there.I keep running into an issue where I want to stabilise a tall and narrow print, and what I thought might work, in fact isn&#039;t working.  That is to say I thought I might be able to ad...]]></description>
                        <content:encoded><![CDATA[<p>Hi there.</p><p>I keep running into an issue where I want to stabilise a tall and narrow print, and what I thought might work, in fact isn't working.  That is to say I thought I might be able to add custom supports to a vertical surface.  Unfortunately when I go to slice the model no supports are generated.  The general suggestion on forums for tall objects seems to be to add support in the model itself.  I can do that, but it just strikes me that I would have expected the approach to paint on a support, even though the surface is vertical, to work.  My latest thinking is that if I tilt the object very slightly, say 0.5 degrees, then supports work.  Alas that's not ideal for the overall look of the model.</p><p>Despite much searching I haven't been able to find much about supports on vertical surfaces.</p><p>Here is an example of the sort of thing I'd like to print vertically (for strength and aesthetic reasons)</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/12/a1967ac4-screenshot_2023-12-08_18-09-12.png"><img class="alignnone size-medium wp-image-160822" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/12/a1967ac4-screenshot_2023-12-08_18-09-12-600x500.png" alt="" width="600" height="500" /></a></p><p>If I tilt the object slightly, then paint on supports...</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/12/bcff2d21-screenshot_2023-12-08_18-10-31.png"><img class="size-medium wp-image-160819" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/12/bcff2d21-screenshot_2023-12-08_18-10-31-600x500.png" alt="" width="600" height="500" /></a></p><p>then slice...</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/12/77ca6207-screenshot_2023-12-08_18-10-58.png"><img class="size-medium wp-image-160820" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/12/77ca6207-screenshot_2023-12-08_18-10-58-600x500.png" alt="" width="600" height="500" /></a></p><p>This works as I hoped.  Alas if I keep the model vertical I don't get any supports at all.</p><p>Any thoughts on whether this is possible?  I'm using V2.6.0.</p>
<div id="wpfa-160823" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1702013764-c1c11160-screenshot_2023-12-08_18-09-12.png" target="_blank" title="c1c11160-screenshot_2023-12-08_18-09-12.png"><i class="fas fa-paperclip"></i>&nbsp;c1c11160-screenshot_2023-12-08_18-09-12.png</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/supports-on-vertical-surfaces-dont-have-any-effect/#post-688325</guid>
