Supported layers are stringy
Page 3 / 3
ssackett
(@ssackett)
Looks good
Which type of soluble support is easiest to work with PVA, BVOH or other?
BTW: I tore my hot end apart today and found nothing in particular wrong with it.  Aside from the possibility that the nozzle may have been clogged (I couldn't tell but it cleaned up well and I didn't see any crud in it). There wasn't a plug above the heat brake and all joints were tight with no oozing.   The PTFE tube was undamaged and measured nearly 45mm, I replaced it with one cut to spec and shaped properly. Given the length of the tube I may have been right about it kinking due to heating, at least it sounds plausible.  I will be doing a test print tonight to see what comes of it.  I won't be trying ABS again until I give it a workout with PETG.
Posted : 04/08/2021 11:11 pm
ssill2
(@ssill2)
Bvoh
Is my go to. Verbatim bvoh
Posted : 05/08/2021 12:59 am
filament
Posted by: @ssill2
That is not a bad filament.
Posted : 05/08/2021 1:21 am
Page 3 / 3
