Supported layers are stringy
Stránka 2 / 3
ssill2
(@ssill2)
not holding out hope on PVA
I've not had good success with PVA.
I was just watching the interface layers go down for the first print and I'm thinking I might have to have less bridging. PVA doesn't bridge well in my experience.  I've never tried to print so much supported material lol.
But maybe I'll try it again with less distance between the supports.
Napsal : 02/08/2021 10:59 pm
ssill2
(@ssill2)
Meh
First attempt it great. Running another with improved settings .  I don’t think I purged enough because there’s some contamination of the pla with pva
Napsal : 03/08/2021 12:11 am
ssackett
(@ssackett)
Renovating the mmu2
I have just found out about the different varieties of PTFE tubing used with the MMU2 (1.85mm ID inside the extruder and 2 to 3mm from the buffer and a special tube between MMU and extruder), also that there is a special heat brake for the hot end.  I have all that stuff on order and will see if it helps any.  Also I am adding Festo Pneumatic connectors to the input of the MMU.  Seems like Prusa should do a better job documenting things like this.  They must have noticed by now how much trouble people are have getting the MMU to work.
Napsal : 03/08/2021 2:13 am
ssill2
(@ssill2)
Let me know how it goes.
I’m 2mm ID throughout and no issues now
oh and here’s latest with soluble.  Not bad but it could be better.
Napsal : 03/08/2021 2:21 am
ssackett
(@ssackett)
PTFE tube length
Do you know what length the PTFE tube in the hot end should be?  I have been trimming it to be as long as possible, but it occurs to me that because the tube swells and softens when heated that this might cause it do deform and create a restriction because it has no room to expand.  The other side of the argument is that if the tube is shorter, that it might result in creating a cavity above the heat break that accumulates melted plastic which hardens into a plug when cooled.  So what do you think?
Napsal : 03/08/2021 6:35 pm
ssill2
(@ssill2)
I don't
I've only used the the ones that came with the assembled hot end.  Hang on, I do have a spare assembled hot end for the MK3S+  I can measure.
Here we go
Napsal : 03/08/2021 6:49 pm
ssackett
(@ssackett)
Chamfer?
Thanks.  From the picture it looks like there's an outside chamfer on one end and an inside chamfer on the other, is this correct and which end is up?
Napsal : 03/08/2021 7:26 pm
ssill2
(@ssill2)
correct
rounded(exterior  chamfer)  end goes down.
Napsal : 03/08/2021 7:29 pm
ssill2
(@ssill2)
Soluble success
Pva + pla.
Napsal : 03/08/2021 11:55 pm
ssackett
(@ssackett)
Nice
What were your parameters and what is the length of the piece?
Napsal : 04/08/2021 12:49 am
ssill2
(@ssill2)
Settings
It’s slightly shorter than the diagonal of the plate.  I sliced it with 2.4 prusaslicer.  I can attach .3mf tomorrow if you want
Napsal : 04/08/2021 12:59 am
ssill2
(@ssill2)
Still on plate
Napsal : 04/08/2021 1:27 am
ssackett
(@ssackett)
File
Yes, I would like to have the 3mf, it will come in handy when I get my MMU running again.
Napsal : 04/08/2021 1:36 am
ssill2
(@ssill2)
RE: as requested
Again this is done with PrusaSlicer 2.4.0 as built from master so don't try to open it on 2.3.3.
Attachment removed
I'm about to print another one of these in ziro silver black to test BVOH.
Napsal : 04/08/2021 2:31 pm
ssackett
(@ssackett)
3MF received
Thanks for the file, please send the BVOH file also once you have success.   BTW: Do you know of any documents that explain what the buttons on the MMU do in reality.  I have never been able to use them successfully in the manner Prusa documents.
Napsal : 04/08/2021 3:55 pm
ssill2
(@ssill2)
same file
The file you have should work, just change filament 5 to be verbatim bvoh.
I also change the layer height for this print to .15 from .2.  otherwise the same settings as the PVA one.
The best practical explanation of all the MMU buttons is here
MMU theory of operation
Napsal : 04/08/2021 3:59 pm
ssackett
(@ssackett)
Excellent, Excellent, Excellent
I'm in love again!  All of my questions were answered and some of my suspicions confirmed, I wish I had seen this two years ago it would have saved hours of confusion and many failed prints.
Napsal : 04/08/2021 6:37 pm
ssill2
(@ssill2)
if you watch it enough
Stuff starts to make sense after you've watched the MMU in operation as much as I have lol.  but I'm truly excited to see this work for you.  It really is cool to see it work.
Napsal : 04/08/2021 6:41 pm
ssill2
(@ssill2)
so far so good
on this bvoh + PLA(Ziro Silver Black)
Napsal : 04/08/2021 7:28 pm
ssill2
(@ssill2)
another flawless mmu print
PLA + BVOH.  I'm almost feeling like trying the Aquasys 120 again and see if I have any luck with it.
Napsal : 04/08/2021 10:48 pm
Stránka 2 / 3
