					                		Support Material For Openings on Part - How do I print this? (Printing help)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/support-material-for-openings-on-part/</link>
                <lastBuildDate>Wed, 17 Jun 2026 20:16:12 +0000</lastBuildDate>
                        <title>RE: Support Material For Openings on Part</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/support-material-for-openings-on-part/#post-729040</link>
                        <pubDate>Thu, 05 Dec 2024 23:38:20 +0000</pubDate>
                        <description><![CDATA[Much appreciated! Learn something new everyday.. I thought those openings were impossible without supports]]></description>
                        <content:encoded><![CDATA[<p>Much appreciated! Learn something new everyday.. I thought those openings were impossible without supports</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Yngeinstn</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/support-material-for-openings-on-part/#post-729040</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/support-material-for-openings-on-part/#post-729036</link>
                        <pubDate>Thu, 05 Dec 2024 22:48:40 +0000</pubDate>
                        <description><![CDATA[It shouldn&#039;t either unless your printers cooling is really really bad.The painting tip was more of a &#039;if you really want to&#039; then you can.]]></description>
                        <content:encoded><![CDATA[<p>It shouldn't either unless your printers cooling is really really bad.</p><p>The painting tip was more of a 'if you really want to' then you can.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Neophyl</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/support-material-for-openings-on-part/#post-729036</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/support-material-for-openings-on-part/#post-729018</link>
                        <pubDate>Thu, 05 Dec 2024 18:52:33 +0000</pubDate>
                        <description><![CDATA[Thanks for the information.. I was unaware that big of an opening can be done without supports. I am guessing that the opening that you were referring to about painting doesn&#039;t need supports...]]></description>
                        <content:encoded><![CDATA[<p>Thanks for the information.. I was unaware that big of an opening can be done without supports. I am guessing that the opening that you were referring to about painting doesn't need supports either?</p>
<p>Okay i will keep where to post in mind the next time.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/support-material-for-openings-on-part/#post-729018</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/support-material-for-openings-on-part/#post-729008</link>
                        <pubDate>Thu, 05 Dec 2024 18:09:18 +0000</pubDate>
                        <description><![CDATA[First you use snug support type and not grid.  Secondly you can then paint a thin strip in the middle of the surface which will make the support narrower.  Adjust until it doesnt go to the b...]]></description>
                        <content:encoded><![CDATA[<p>First you use snug support type and not grid.  Secondly you can then paint a thin strip in the middle of the surface which will make the support narrower.  Adjust until it doesnt go to the base plate. </p>
<p>Thirdly yes all those opening do <strong>not</strong> need support.  They will bridge.  While they may sag slightly in the middle there will easily be enough clearance built in for that not to be a problem.  </p>
<p>Finally, this question really belong in the prusa slicer sub forum at the bottom of this site :)</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/support-material-for-openings-on-part/#post-729008</guid>
                        <title>Support Material For Openings on Part</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/support-material-for-openings-on-part/#post-728987</link>
                        <pubDate>Thu, 05 Dec 2024 15:15:07 +0000</pubDate>
                        <description><![CDATA[So i am trying to print the Prusa MK3 Mean Well LRS-350 Specific Mount. The guide says not to use support except for a small point on the base plate. I am looking at the PSU cover and i don&#039;...]]></description>
                        <content:encoded><![CDATA[<p>So i am trying to print the <a href="https://www.thingiverse.com/thing:3329838" target="_blank" rel="noopener">Prusa MK3 Mean Well LRS-350 Specific Mount.</a> The guide says not to use support except for a small point on the base plate. I am looking at the PSU cover and i don't see how it would be able to print without supports. 1) Can this PSU cover really be printed without supports? 2) I can handle putting supports  for opening #1 and #2 however, there is this opening #3 that starts at layer 47.40 that i am unsure about. How can you put supports for JUST the opening instead of it having to start from the build plate?</p>
<p>Thanks in Advance</p>
<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/12/ed062658-preslice_psu.png"><img class="alignnone size-full wp-image-172294" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/12/ed062658-preslice_psu.png" alt="" width="550" height="402" /></a><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/12/171fc6ae-postslice_psu.png"><img class="alignnone size-medium wp-image-172295" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/12/171fc6ae-postslice_psu-547x500.png" alt="" width="547" height="500" /></a></p>
<div id="wpfa-172297" class="wpforo-attached-file"><a class="wpforo-default-attachment" title="4e3ffe2d-postslice_psu.PNG" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1733411707-4e3ffe2d-postslice_psu.png" target="_blank" rel="noopener"> 4e3ffe2d-postslice_psu.PNG</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/support-material-for-openings-on-part/#post-728987</guid>
