Support Improvement
New mk3 user here!
Recently I printed out the hammer head of Thor's Hammer. It used supports around the base and for the sides.
When it finished, it actually came out a better than I was expecting. The top 3/4ths of the model were near perfect. However the bottom part had a bunch of deformities, many around where the supports are, as shown in the picture be
I was thinking to simply increase the density of the supports or something, and possibly flipping the model over (Which I should have done in the first place), but if anyone has had this issue before and have successfully fixed it, do you mind pointing me in the right direction?
My temperature settings are 215, 70 for first layer; 200, 60 for the rest.
Thanks!
Re: Support Improvement
If that's your bottom layer, you may have a few things going on:
Alright, I'll try to reprint it later with a different orientation. Thanks for the advice!
