Steelfill not loading into extruder MK3S/MMU2S
Hi, I am trying to load Steel fill for printing.
The MMU2S loads it fine and before printing it feeds into the extruder, then after waiting for temperatures, when it has to start extruding, I only hear loud clicking noise and extruder idler jumps, then it aborts the loading and the MMU2S retracts the fillament. wait for a while and then tries again. but the steel fill does not load into the extruder.
I am using " Color Fabb " Steelfill, bed temp at 60 degrees, extruder at 210 degrees, previous material in extruder was Prusa ABS or Prusa PETG
I would appreciate some help. Thanks
SMIDDIE
Posted : 03/04/2020 10:00 am
RE: Steelfill not loading into extruder MK3S/MMU2S
Hey,
I am having the same issue. Did you find a resolution?
Posted : 28/10/2020 6:29 pm
