Smartfil PLA 3D850,
Pagina 2 / 2
Ringarn67
(@ringarn67)
RE: Smartfil PLA 3D850,
@arjan
My knowledge and experience in 3d-printing is not worth so much, I leave the problem solving to others and learn from them 👍
There are some real magicians on this forum
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Postato : 21/05/2021 7:28 pm
Yep - Bondtech tension, but there is a lot going on in the way the part is being sliced.  Here's how I would approach it.
Mod v2_Cuerpo v2 - tm
I'd first do a test print as shown, looking for the artifacts in the first few layers where there is a large overhanging perimeter. Support may or may not help with cosmetics.  The enforcer slab may not be needed - it'll be a judgement call.
And I don't see why this part needs to be solid - so I dropped infill back to 25%. I also slowed down print speeds and reduced flow rate to something common flex will tolerate.
Postato : 21/05/2021 7:31 pm
arjan
(@arjan)
I will try to do as you indicate, thank you very much
Questo post è stato modificato 5 years fa da arjan
Postato : 21/05/2021 7:53 pm
arjan
(@arjan)
Posted by: @arjan
@tim-2
Let's see if I've done it right now, thank you very much
Postato : 22/05/2021 2:41 pm
arjan
(@arjan)
@tim-2
with a little delay, but thank you very much it worked very well
Postato : 30/05/2021 9:53 am
Macmonty
(@macmonty)
I have same problem, but the uploaded file isn’t avalaible, can you reupload please ?
Regards
Postato : 24/04/2022 8:41 pm
MrB
 MrB
(@mrb)
How hot are you printing? Try bumping up your nozzle temperature. 3D850 likes it hot.  I had this exact same problem.
Posted by: @arjan
Hi, I'm having a problem printing with this filament, I have tried several configurations, the extruder starts making noise tac tac tac and at the end the filament stops coming out, it happened to someone else and they could solve it. Thank you
Postato : 03/05/2022 2:21 am
Pagina 2 / 2
