slicing/printing a torus segment
And another stupid question from me...
I'm trying to print a torus segment with a hole in the bottom and a pin at the top. To achieve a degree of translucency the main part should be printed with 0% if. Pruca Slicer unfortunately only slices perpendicular to the build plate. This results in the slicing pattern on the second image (upside down, because I tried it that way as well). I also tried tilting the modifier that changes if from 0 to a higher value.
Is there a way to fix this in Slicer or is there another slicer around that could do this?
As always many thanks for your help and ideas.
Napsal : 11/01/2020 10:15 pm
