Slic3r overhangs
Hey everyone, I have found with Slic3r I don't get the same quality on overhangs as I do with S3D. Everything else I have found the default profile in Slic3r to do great. What have you found to help with overhang areas that can be printed without supports, but have rough layer lines.
Veröffentlicht : 15/10/2018 3:44 pm
Re: Slic3r overhangs
You didn't mention what materials or settings you're using, but usually more cooling, lower temps helps with overhangs. If your bed temp is high, you might knock it down some as well.
Veröffentlicht : 15/10/2018 10:55 pm
