Shifted layer
Hi there,
I have problem with shifted layers. It happens repeatedly after 10-15 minutes of printing. I have calibrated the printer, reset with Wizard to factory settings. Models are well sliced. Models from the past has the same problem.
The problem started with original G-Code for COVID shield from Prusa. I printed approximately 40 shields. See the attached images, please. I also checked the belt tension and it seems to be in the recommended range. Could you please give me any help?
Thank you,
Ladislav
Postato : 14/04/2020 12:46 pm
RE: Shifted layer
Check the x-axis grub screws
Postato : 14/04/2020 1:34 pm
