Repeatable surface artifacts help
Leeidas
(@leeidas)
After some help please.
I am trying to print some moulds for my missus in prusament PC, I have printed the same mould multiple times with the same artifacts in the same place, so it is repeatable.
From the pics you can see the multiple artefacts are in vertical alignment and appear in the top right area of the printer.
I have sliced the same print in Slicer changing layer height and even tried playing with the seam position but i get the same 5 artifacts in the same place.
The mould is my own design and i exported from Fusion360 if that could be a contributing factor.
Any help or advice please?
Opublikowany : 19/07/2020 8:08 am
