PrusaSlicer won't render correctly
John Cook
(@john-cook)
PrusaSlicer 2.3.2
I import a .3MF file (Pic 1) and select Export G-code. It produces the wrong rendering (Pic 2) just showing the base ring without the tube part of the model. What is happening here - I need the whole part rendered so I can print it all.
Posted : 20/11/2022 12:57 am
RE: PrusaSlicer won't render correctly
Could be many things. Could be a faulty model or the model thickness may be too small for the extrusion width in the missing area etc etc.
we would need a copy of your 3mf project to check. If you want to attach it then you must zip it up or the forum software won’t accept the file. It just won’t attach.
Posted : 20/11/2022 1:05 am
John Cook
(@john-cook)
I had the tube thickness at .75mm and a length of 20mm, apparently it didn't like those dimensions. I've increased the thickness to 1mm and it took. Printing it off now. Thanks.
Posted : 20/11/2022 1:40 am
