					                		Problem with first layer after breakdown - How do I print this? (Printing help)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/problem-with-first-layer-after-breakdown/</link>
                <lastBuildDate>Mon, 11 May 2026 02:27:03 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/problem-with-first-layer-after-breakdown/#post-622121</link>
                        <pubDate>Sat, 01 Oct 2022 22:25:20 +0000</pubDate>
                        <description><![CDATA[Your first layer Z calibration is too low. Cheerio,]]></description>
                        <content:encoded><![CDATA[<p>Your first layer Z calibration is too low. </p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/problem-with-first-layer-after-breakdown/#post-622121</guid>
                        <title>Problem with first layer after breakdown</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/problem-with-first-layer-after-breakdown/#post-622112</link>
                        <pubDate>Sat, 01 Oct 2022 18:53:14 +0000</pubDate>
                        <description><![CDATA[Hello,Ever since I&#039;ve got a new heat sensor for the extruder (after reporting an issue with the printer Prusa sent me one) the first leyer of the print is off.The issue being that thethe ext...]]></description>
                        <content:encoded><![CDATA[<p>Hello,<br />Ever since I've got a new heat sensor for the extruder (after reporting an issue with the printer Prusa sent me one) the first leyer of the print is off.<br />The issue being that thethe extruder heated up to 400 C and the printer halted with a squeak. Before that happened the print and first leyer always was top notch, even on lenghty prints which is not the case now. Now on short/narrow prints are fine but longer/wider ones are not as smooth. <br />I did total reset of EEPROM and reset everything again from the start but unfortunately that didn't change anything, and it's still as bad as it was.<br />I've tried couple dozens of diffrent settings and hights (some even recomnded by a Prusa emloyee) but nothing is coming even close to what it was before the malfunction accoured.<br />I have a new set up (on a block of concrete to reduce vibrations) and added a new filament handle to ease the frame from it. I even tighten the belt and everything else, and still nothing.<br />I'm out of ideas now, maybe someone has some suggestion please?<br />I'm attaching some pictures where the issue is highlighted - red being bad and yellow good.</p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2022/10/20221001_202603-scaled.jpg"><img class="alignnone size-medium wp-image-145644" src="https://forum.prusa3d.com/wp-content/uploads/2022/10/20221001_202603-600x500.jpg" alt="" width="600" height="500" /></a><a href="https://forum.prusa3d.com/wp-content/uploads/2022/10/20221001_202644-scaled.jpg"><img class="alignnone size-medium wp-image-145646" src="https://forum.prusa3d.com/wp-content/uploads/2022/10/20221001_202644-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>XD3Dpl</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/problem-with-first-layer-after-breakdown/#post-622112</guid>
