RE: Printing setting
Layer one is not properly set, but this has little to do with the bridging.
The only way to improve the bridging performance it to use supports.
Here's some good guidance for default values to try:
0.25mm z distance
3mm pattern spacing
4 interface layers
75% xy distance
0.2mm interface layer spacing
I assume what we're seeing is the bottom of the object. As @tim-2 said, you should use supports. Or, if the other side is flat, flip the object around.
On this object if your not willing to flip it, you could also change the "bridging angle" to something like 45 degrees this should shorten the span of the bridge and produce a better result.
The best thing would be for you to post a Zipped .3mf project file so we could look at the settings and identify the problems.
Good Luck
Swiss_Cheese
The Filament Whisperer
Thank you for all your answer. 😀 😀 😀 Sorry, I don't have the good habits yet.
Yes, the picutre is th bottom (it's obvious I should have say it).
Here is the .3mf file. I don't know nothing about the setting. Even for the filling rate and main setting. 🤔 🤔
Thank you for your help...
here is the zipped file
@herve
Try these settings, I adjusted the Bridge fill angle to 45 degrees, and the perimeters extrusion width to 0.4 in the hopes that it will help you get better detail.
Here is the adjusted .3mf project file Licorne Elena_Swiss.3mf
I hope this helps, please let us know how the print turns out.
regards
Swiss_Cheese
Thank you so much. I will look at your setting and pring again. 😀 😀 😛
