					                		Printing problems. Filament Clumps. - How do I print this? (Printing help)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/</link>
                <lastBuildDate>Fri, 06 Mar 2026 14:13:57 +0000</lastBuildDate>
                        <title>RE: Printing problems. Filament Clumps.</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-325291</link>
                        <pubDate>Tue, 15 Dec 2020 23:58:06 +0000</pubDate>
                        <description><![CDATA[@kilawoNozzles made of steel (hardened) is not as heat conductive as brass or copper. You may need to print with higher temperature (+5 -&gt; 10 C) to avoid de-lamination when printing PETG ...]]></description>
                        <content:encoded><![CDATA[<p>@kilawo</p><p>Nozzles made of steel (hardened) is not as heat conductive as brass or copper. You may need to print with higher temperature (+5 -&gt; 10 C) to avoid de-lamination when printing PETG or other higher temperature filaments.</p><p>The plated nozzles I use from Micro Swiss has a brass/copper core that conduct heat like the nozzles from Prusa. The plating is much harder than brass and will resist wear and still give a low friction surface.<br />The HSS steel, ruby and carbide nozzles are for more abrasive filaments like carbon/glass fiber and <em>glow in the dark</em> Filaments - they may need the standard profiles to be adjusted to give the best print result.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Area51</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-325291</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-325039</link>
                        <pubDate>Tue, 15 Dec 2020 14:47:19 +0000</pubDate>
                        <description><![CDATA[Hello,Thanks for your tips.I just purchased two Micro-Swiss High Speed Hardened Steel Nozzles for E3D V5-V6, nickel plated for Prusa MK3S, from Germany.]]></description>
                        <content:encoded><![CDATA[<p>Hello,</p><p><span class="VIiyi" lang="en"><span class="JLqJ4b ChMk0b" data-language-for-alternatives="en" data-language-to-translate-into="es" data-phrase-index="0">Thanks for your tips</span></span>.</p><p><span class="VIiyi" lang="en"><span class="JLqJ4b ChMk0b" data-language-for-alternatives="en" data-language-to-translate-into="es" data-phrase-index="1">I just purchased two Micro-Swiss High Speed Hardened Steel Nozzles for E3D V5-V6, nickel plated for Prusa MK3S</span></span>, from Germany.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Kilawo</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-325039</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-324943</link>
                        <pubDate>Tue, 15 Dec 2020 11:47:27 +0000</pubDate>
                        <description><![CDATA[To me it looks like you are using the smooth PEI steel sheet - if so, it is important that you use a release agent like windows cleaner before every print to avoid the PETG part to get stuck...]]></description>
                        <content:encoded><![CDATA[<p>To me it looks like you are using the smooth PEI steel sheet - if so, it is important that you use a release agent like windows cleaner before every print to avoid the PETG part to get stuck on the build plate.</p><p>If it is the textured steel sheet, no release agent is necessary, just a clean surface.</p><p>PETG really likes to stick to the brass nozzle so I always clean the outside of the nozzle before every print to prevent build up.<br />A nickel plated nozzle from E3D or MicroSwiss helps with keeping the nozzle clean. All my printers now have plated nozzles (they are a direct replacement of the original nozzles).</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-324943</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-324880</link>
                        <pubDate>Tue, 15 Dec 2020 09:41:33 +0000</pubDate>
                        <description><![CDATA[I use Prusa&#039;s temperature settings for PETG 240 / 85º Celsius (464 / 185ºF). Then I&#039;ll lower the temperature a bit. The Z axis setting is -1,400. I&#039;ll do tests. And I&#039;ll clean the bed with s...]]></description>
                        <content:encoded><![CDATA[<p><span class="VIiyi" lang="en"><span class="JLqJ4b ChMk0b" data-language-for-alternatives="en" data-language-to-translate-into="es" data-phrase-index="0">I use Prusa's temperature settings for PETG 240 / 85º Celsius (464 / 185ºF).</span> <span class="JLqJ4b ChMk0b" data-language-for-alternatives="en" data-language-to-translate-into="es" data-phrase-index="1">Then I'll lower the temperature a bit.</span> <span class="JLqJ4b ChMk0b" data-language-for-alternatives="en" data-language-to-translate-into="es" data-phrase-index="2">The Z axis setting is -1,400.</span> <span class="JLqJ4b ChMk0b" data-language-for-alternatives="en" data-language-to-translate-into="es" data-phrase-index="3">I'll do tests.</span> <span class="JLqJ4b ChMk0b" data-language-for-alternatives="en" data-language-to-translate-into="es" data-phrase-index="4">And I'll clean the bed with soap.</span></span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-324880</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-324877</link>
                        <pubDate>Tue, 15 Dec 2020 09:28:34 +0000</pubDate>
                        <description><![CDATA[Thank you very much to both 😊I will study all your recommendations, and apply them. In a few days I will write here, the results.]]></description>
                        <content:encoded><![CDATA[<p><span class="VIiyi" lang="en"><span class="JLqJ4b ChMk0b" data-language-for-alternatives="en" data-language-to-translate-into="es" data-phrase-index="0">Thank you very much to both</span></span> 😊</p><p><span class="VIiyi" lang="en"><span class="JLqJ4b ChMk0b" data-language-for-alternatives="en" data-language-to-translate-into="es" data-phrase-index="0">I will study all your recommendations, and apply them.</span> <span class="JLqJ4b ChMk0b" data-language-for-alternatives="en" data-language-to-translate-into="es" data-phrase-index="1">In a few days I will write here, the results.</span></span></p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-324877</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-324661</link>
                        <pubDate>Mon, 14 Dec 2020 22:19:18 +0000</pubDate>
                        <description><![CDATA[That looks like your Live-Z is too low and the nozzle is scraping up filament on your 1st layer. PETG requires a bit less squish (a less negative Live-Z value) than PLA. Recommendations are ...]]></description>
                        <content:encoded><![CDATA[<p>That looks like your Live-Z is too low and the nozzle is scraping up filament on your 1st layer. PETG requires a bit less squish (a less negative Live-Z value) than PLA. Recommendations are to raise your Live-Z (make it less negative) by 0.02-0.2mm when switching to PETG.</p><div data-pm-slice="1 1 " data-en-clipboard="true">If you have not already done so, try using Jeff Jordan's "<a href="https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f62/life-adjust-z-my-way-t2981.html" rev="en_rl_none">Life Adjust</a>" procedure for calibrating your Live-Z setting. It is much easier to use and understand than the onboard routine and much easier to make mid-print adjustments accurately with. In general, start high (less negative) and work lower (more negative) in large increments (e.g. 0.1mm) until the filament starts to stick on its own. When you've got your Live-Z setting adjusted properly, you should be able to gently rub the extruded lines on the PEI surface without dislodging them.  Then start lowering (more negative) the level until there are no gaps between layers. You should not be able to peel the lines apart after printing, but the top should be regular. </div>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>bobstro</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-324661</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-324607</link>
                        <pubDate>Mon, 14 Dec 2020 21:06:40 +0000</pubDate>
                        <description><![CDATA[Try,First layer to be 100%(yours look good to me)Clean bed with dish soap only.Lower temperature for nozzle.I had with petg during the print, little blobs on print, i did a lower temperature...]]></description>
                        <content:encoded><![CDATA[<p>Try,</p><p>First layer to be 100%(yours look good to me)</p><p>Clean bed with dish soap only.</p><p>Lower temperature for nozzle.</p><p>I had with petg during the print, little blobs on print, i did a lower temperature and a little less extrusion multiplier.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Peter M</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-324607</guid>
                        <title>Printing problems. Filament Clumps.</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-324508</link>
                        <pubDate>Mon, 14 Dec 2020 19:30:05 +0000</pubDate>
                        <description><![CDATA[Hello!I own the printer for over a year and have never had a problem. But a week ago, sometimes, pasty areas (clumps) are printed as in the image.I have totally r...]]></description>
                        <content:encoded><![CDATA[<p></p><p>Hello!</p><p>I own the printer for over a year and have never had a problem. But a week ago, sometimes, pasty areas (clumps) are printed as in the image.</p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2020/12/IMG_20201214_1952371.jpg"><img class="alignnone size-medium wp-image-61666" src="https://forum.prusa3d.com/wp-content/uploads/2020/12/IMG_20201214_1952371-600x500.jpg" alt="" width="600" height="500" /></a></p><p>I have totally recalibrated the printer. I have changed the nozzle. I have reinstalled Slicer. I have tried printing with supports or without supports.</p><p>Also, it is very difficult to remove the support, if I use it.</p><p>I need your help.</p><p>Does anyone know what is happening?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/printing-problems-filament-clumps/#post-324508</guid>
