Printing failed half way through
bmcduffie89
(@bmcduffie89)
I want to start off and say that I am extremely new to 3d printing. I've finally got interested and purchased a 3d printer for miniatures; however, I can not figure out why my print is messing up halfway through. I have the Prusa MK3S with an auto-leveling bed with Prusa's PLA filament. I'm printing at 200 degrees since 215 degress caused stringing between the legs. It seems to be messing up at the same spot every time.
Would anyone have any opinions as to what I am doing wrong? Please use layman's terms for me as I am still a newb and learning the basics. Thanks again for any and all help.
Este debate ha sido modificado el hace 7 years 2 veces por bmcduffie89
Respondido : 06/10/2019 2:27 pm
RE: Printing failed half way through
I suspect that you are suffering from a blockage caused by lots of retractions
reducing he length of the retractions may help
Respondido : 06/10/2019 4:11 pm
bmcduffie89
(@bmcduffie89)
@joantabb
I will try that if this current print fails again. I have been tweaking after it fails but will do what you suggest next. Thanks for the suggestion!
Respondido : 06/10/2019 5:24 pm
Good Luck!
Joan
Respondido : 06/10/2019 6:45 pm
Miembro
Similar issue.  I used a combo of cold pulls and cleaning filament to fix it.
Respondido : 06/10/2019 7:02 pm
