Print Shifts Part Way Through
I'm having problems with a print that shifts in the middle for no apparent reason. I've tried recreating the gcode to see if the file was corrupted, but it still behaves the same. The print is staying stuck to the platform, so it's not like it's sliding around. Can anyone tell me what is going on and how to fix it?
Sample print:
https://flic.kr/p/P7MVHN
https://flic.kr/p/P7MVBL
Model:
gcode: https://www.dropbox.com/s/rwy53t4k4loijfv/BeaverCowl_IML.gcode?dl=0
stl: https://www.dropbox.com/s/aqvkn6fq5bqhww2/BeaverCowl_IML.stl?dl=0
Re: Print Shifts Part Way Through
did you you recently flash 3.4 and if so did it work before? assuming its not the usual suspects like drive pulleys slipping on the shaft, I did have a few layer shifts (octoprint) come up out of nowhere on 3.4 so i'm back on the previous version for the time being.
also, check your per-print fail stats and see if its detecting any erroneous crashes. if so you could try disabling the sensor.
