PLA 850/870
Boltian
(@boltian)
PLA 850/870
Hello,
I have got some spools of PLA 3D850 and 3D870 from SAKATA 3D. These materials are formulated by Natureworks.
My experience at the beginning was very bad due to following the printing instruction from the manufacturer, the MK3S got clog continuously.
After some investigations and with the help of the SAKATA support team, It's seen to be that the issue comes from the configuration (hardware and software) of the extruder of the MK3S. The reason is that in other printers like Ender, Ultimaker or Volumic (I have tested the filament on these ones) work without problem at 210ºC (specification says  that working temp. between 205ºC-225ºC).
But in the MK3S I have to set the temperature to 230ºC, and the print process works. I cannot never set the first layer speed under 25mm/s. In opposite case the extruder get clog.
Obviously these PLAs composition are different, they are a little bit hard compared with Prusa PLAs.
For you information I have used these parameters:
Nozzle temp. (All layers): 230ºC
Bed temp.: 1st layer= 65ºC, The rest layers= 50ºC
Retractions: Distance = 0.7mm, Speed=30mm/s
Accelerations: Infill= 1600mm/s, Perimeters= 1600mm/s, Top/Bottom= 1000mm/s, 1st layer= 1000mm/s
I hope this can help people with try to print this kind of materials, but I would like that you share your experiences.
Este debate ha sido modificado el hace 6 years 2 veces por Boltian
Respondido : 30/01/2020 8:29 pm
3 les gusta
RE: PLA 850/870
I have never had chance to work with those filaments
Which Slicer are you using?
Prusa Slicer?
are you in advanced or expert mode? there are more variables to try.
for PLA I usually turn retraction down to 0.4mm and Z lift to 0.4mm, I generally use heatbed at 70c for all layers... and generally  extruder 215 / 210 temperature!
Respondido : 30/01/2020 8:41 pm
Nikolai
(@nikolai)
RE: PLA 850/870
@boltian
Thanks for sharing. It's always a good idea to print temp tower if you're using a new filament. Comparing print temperatures between different printers is not meaningful. Different extruder designs will always be different.
@joantabb
This looks like HTPLA filament. Usually it need to be printed with higher temp.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Respondido : 30/01/2020 8:52 pm
Boltian
(@boltian)
RE: PLA 850/870
@joantabb
I have used PrusaSlicer 2.1.1 and Cura. In both cases the clog appears in constant movement, eg: when fill the first layer of a 150mm x 80mm rectangle. In my case, I think that it is not problem with the retractions, it's due to deposition rate which is very bad if I set the temperature between 205-215. But in any case i will try with the proposal parameters by you.
@nikolai-r
You are right and I agree with you. Maybe, the Prusa I+D team should study this topic and prepare specific profiles for this kind of materials (HTPLAs) in PrusaSlicer. They knows perfectly the configuration of the extruder and the firmware which manage it, so they can detect very quickly the correct configuration.
I have seen in this forums a post ( https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/problem-with-3d850-pla-filament/ ) where there are people with the same troubles.
Respondido : 31/01/2020 12:52 pm
Sembazuru
(@sembazuru)
RE: PLA 850/870
If you don't have an MMU2, nor plan on having one you may want to consider changing from the Prusa modified heatbreak to a stock E3D heatbreak. See this for more details:
I've heard that some people with MMU2 units also doing this successfully, but I don't remember any details so take it as a rumor.
See my (limited) designs on:
Respondido : 31/01/2020 2:43 pm
Boltian
(@boltian)
RE: PLA 850/870
@sembazuru
Thank you very much. That is the issue. After a lot of test with infinity configurations, I decided to change the heatbreak by the original version from E3D, and in this case, I have replaced the Prusa version to the titanium version. And the results..., no more clogs or jams with this kind of materials.
I have tested the material at 215ºC and 0.4mm of retractions. Worked fine, but at some prints, I got clogs.
Now, I print to 210ºC using the standard Prusa profile without any issues. Before, for me was it impossible to print to this temperature.
Respondido : 15/02/2020 1:16 pm
1 les gusta
Frank_The_Rock
(@frank_the_rock)
RE: PLA 850/870
Cant pot I get 403 wordpress error ?
Respondido : 23/03/2020 11:16 am
Frank_The_Rock
(@frank_the_rock)
RE: PLA 850/870
Cant pot I get 403 wordpress error ? vpost to long?
I am playing with this material also.  I had no Jam but if i do to much retraction it will not extrude properly and sometime after a print the extruder would be clicking and wont start unless I unload and cut filament (big bulge at the end) . I was experiencing those kind of trouble since I had a clog with Glow in the dark and needed to change nozzle (replace by a cheep one and forgot it was there still)  So i order a Nozzle X from E3d work great once it was temp calibrated .
I was able to print normally since then even big retraction part. But this 3D850 form Ingeo PLA fail to do those High retraction part, as I am trying to make a filament profile I decided to do the Heat break replacement for a standard E3D Titanium, even if my profile still need tuning I can Finish those High retraction pieces.  I did an extrusion calibration cube , now my last layer look bad like it as to much material in the filled part... I am using , 212 c Nozzle(215 first), 65 c Bed and the prusament profile.
First green= Before Heat break, the top was all crumbly, Second green after with same parameter, 3 Mystic red before heatbreak with Nozzle X, Grey same thing  The extrusion factor is at 1.04 I will try to lower it a bit, the bad part was a Carabiner with almost only wall so no place to push any material down...
But typing this I just realised I calibrated at 0.200 and the carabiner printed at 0.3 could it make a difference?  I guess so...  Ill send a Calibration cube at .300 to find out.  its aiming for 1.14/2 = 0.57 I had a avg of 0.603mm
I printed a cap that has those filament like badly fuse? They look bigger then string, so do I might need more heat, I will try 215c/65c  If anyone from Prusa Research Team see this,  feel free to do a blog or video on the way you proceed to do a filament profile/calibration that would be awesome and very instructive!!! Stay safe!
Esta publicación ha sido modificada el hace 6 years por Frank_The_Rock
Respondido : 23/03/2020 11:21 am
Frank_The_Rock
(@frank_the_rock)
RE: PLA 850/870
Respondido : 23/03/2020 11:29 am
waltercrundwell
(@waltercrundwell)
RE: PLA 850/870
Posted by: @boltian
Hello,
thank-you so much!!!... 230 was the answer... I also reduced the fan speed and made a huge diference... the rest of your settings don't make a lot of sense to me as I am not that detailed. I use the live tuning setting more.. my flow rate is 100, speed 100, nozzle 230, bed 60/40... and fan 150... is working beautifully now with the stock heatsinc
Respondido : 24/07/2020 7:23 am
c4v
 c4v
(@c4v)
RE: PLA 850/870
Thank you! This was the most complicated filament to get right. Shouldn't the company Sakata have better instructions?
Respondido : 11/10/2022 2:34 am
alvaroachu
(@alvaroachu)
RE: PLA 850/870
Hi:
I also have Sakata 3D 850 PLA filament.
I don't know if you still have access to this forum, @boltian.
Could you please send me the profile so I can import it into Prusaslicer?
My machine is the MK3S+, and when I use generic PLA, I often run into a lot of problems, and I don’t know why...
Could you send me an email  the file
Thank you very much
And sorry for the trouble.
Posted by: @boltian
Hello,
Respondido : 26/03/2026 10:46 pm
