PINDA adjustment
My Z adjustment is flattening the filament at a ZERO setting
How do I correct this ? Do I raise or lower the PINDA sensor?
What's the best to adjust this?
using a i3 mk3s
Russell Lauffer
Respondido : 08/10/2020 6:56 pm
RE: PINDA adjustment
if you lower the pinda 1 click, (effectively one turn, ) you should gain 1.0mm extra gap under the nozzle. this may be enough to give you a little adjustment
Respondido : 09/10/2020 8:24 pm
