PETG Print Quality Challenges
Hi again everyone and greetings from California.
I'm having some issues with PETG. It's an Amazon Basics Black PETG spool, it had great reviews.
I'm using the Slicer "Generic PET" setting.
The challenges seems to be non-uniform extrusion, where I will get 'blobs' of material, for example see attached photo.
The first layer seems to be good, and the bottom is smooth so I know Z is good.
I have no such challenges with PLA or ABS. With both I get excellent results.
I also have no adhesion issues, I've been following the recommendations on this forum to use Windex and it works great.
Could it be a faulty spool? Perhaps the settings should be adjusted?
Thanks in advance for any tip.
Ami
Re: PETG Print Quality Challenges
It is hard to tell from that image. Under extrusion or Live Z is off.
How much maintenance do you do to the insides of the extrusion path? I clean very thoroughly when changing types.
For starters, your layer 1 looks much too low: you are scraping the bed with the nozzle. Other issues look like temperature and/or a nozzle jam induced by being too low.
I use Amazon PETG in black and other colors and find it prints very well, very easily, just needs a clean bed to stick down : unlike every other PETG that normally sticks to even filthy beds like superglue ... Windexs kills a print for me.
Try a cold pull, get any overcooked PLA out of the nozzle.
If you change filament type, check your first layer for z height, this can change if bed a different temperture.
And even better, every print you should check the first layer, it can change.
Thank you all for your replies.
I calibrated first layer Z based on the results of the bottom layer, which seems to be uniform for all other materials.
I will try to increase live Z a bit and see how that impacts things.
Regarding thorough cleaning - can you provide a link to a good article / video with best practices for deep cleaning the extrusion path?
Thanks again,
Ami
Here's some copypasta to get you started...
[...] Regarding thorough cleaning - can you provide a link to a good article / video with best practices for deep cleaning the extrusion path?
Adhesion problems are usually caused by 2 main problems:
And above all else, avoid touching the PEI print surface.
Try those 2 steps. If you're uncertain of the Live-Z results, post pics here of the 75x75 print bottom and you'll get quick help. In general, start high (less negative) and work lower (more negative) in large increments (e.g. 0.1mm) until the filament starts to stick on its own. When it's right, you should be able to gently rub it without it coming loose. Then start lowering (more negative) the level until there are no gaps between layers.
As for the extrusion path:
If you want more detail, I've dumped everything I know about adhesion and bed cleaning here and Live-Z calibration here (draft). Note on cold pulls here. Pics and incomplete notes on the feed path check here.
