Perimeters Not Crossing at Start and End Points, Causing Gap
Hello All,
Does anyone know how I might be able to eliminate this? There seems to be a gap between perimeter start and stop points.
This is causing a gap in my part.
Any idea which settings in Slic3r I can adjust?
I use a Prusa MK3.
Thanks!
Postato : 27/02/2019 3:55 pm
Re: Perimeters Not Crossing at Start and End Points, Causing Gap
You could try adjusting the print settings tab, layers and perimeters, advanced, seam position to random or, spiral vase setting in the print settings, vertical shells, if it is possible. Hover the cursor over the spiral vase words and it will tell you the requirements for the print to let you know if it is possible.
Strange women, laying in ponds, distributing swords, is hardly a basis for a system of governance!
Postato : 28/02/2019 1:54 am
