Optimizing the perimeters path at the cost of small gaps
Hello. I'm printing following model:
The problem is where the ribs are join - the slicer places a very small parts of yellow perimeter. That slows down the printing and also sometimes they are wiped from the head on following movements.
My target is to make the movement like on the picture below, but cannot find the right settings.
Opublikowany : 18/02/2023 10:20 am
Topic starter
answered:
RE: Optimizing the perimeters path at the cost of small gaps
I reply to myself. This is a template with wall thickness from 0,5mm to 1.9mm in 0.1mm steps. The target result is at 1.5 thickness. Also thicker walls are ok with 0% infill.
0% infill
100% infill
Opublikowany : 18/02/2023 7:11 pm
