missing walls
Just wondering if someone can help me with this?
I am trying to print a model with cavities for magnets, leaving a 0.4 mm wall.
In Prusaslicer 2.5 these come up as a solid line but when I try to print the model, my mk3s+ leaves a gap instead of printing the whole wall. This happens on all three cavities. I've had this happened twice now.
Opublikowany : 01/11/2022 12:04 pm
If you are using the standard nozzle the default extrusion width is 0.45mm; your wall is narrower ...
Redesign with a 0.9mm+ wall and you will get a strong enclosure.
Opublikowany : 01/11/2022 3:20 pm
Topic starter
answered:
RE: missing walls
Thank you! Will make the changes and try again.
Opublikowany : 01/11/2022 7:21 pm
