jam in nozzle when getting to a detail (Prusament PETG)
PW
 PW
(@pw-3)
Please see picture (lower right corner)- the print of the detail (6mm pipe 10mm long with 2.5mm hole) results in a jam in the nozzle and the Prusament PETG grinds in the extruder gear. When unloading and loading filament all is ok until that Detail.
I printed a small piece, it works (see left side). I suspect this is a temperature cooling stetting that I do not get... any help would be very welcome!
I also printed yesterday the Extruder MK3S to MK3S+ upgrade (6h20m PETG), 1st attempt no issue marvelous print (so this issue is with the MK3S and MK3S+ extruder assembly).
Respondido : 10/04/2022 2:41 pm
Kalimero
(@kalimero)
RE: jam in nozzle when getting to a detail (Prusament PETG)
Do you really have an MK3S extruder on your MINI printer?
Nejsem zaměstnancem Prusa Research.
Respondido : 10/04/2022 3:18 pm
PW
 PW
(@pw-3)
Sorry - no a MK3S+ now - sorry by accident I hit the wrong folder - thank you for pointing that out.
I repost in the right place - and try to close or delete here
Respondido : 10/04/2022 3:23 pm
I moved the thread, I hope this is helpful1
Respondido : 23/04/2022 8:28 am
