issue with my Prusa i3 MK3 3D printer
Hello everyone, I've been encountering an issue with my Prusa i3 MK3 3D printer recently. When I start a print, the first few layers go down perfectly, but after a while, the print quality deteriorates, and I start to see gaps and under-extrusion. I've checked the nozzle, cleaned it, and made sure my filament is of good quality. What could be causing this problem, and how can I troubleshoot and fix it?
Best Answer by Robin_13:
Check the extruder teeth are clean and that the grub screws are tight. Also that it is aligned properly with the filament.
Postato : 05/11/2023 5:37 pm
RE: issue with my Prusa i3 MK3 3D printer
Postato : 09/11/2023 11:01 pm
1 persone hanno apprezzato
Postato : 14/11/2023 10:09 am
