issue with my Prusa i3 MK3 3D printer
Afrasiab Sajid
(@afrasiab-sajid)
Membre
Hello everyone, I've been encountering an issue with my Prusa i3 MK3 3D printer recently. When I start a print, the first few layers go down perfectly, but after a while, the print quality deteriorates, and I start to see gaps and under-extrusion. I've checked the nozzle, cleaned it, and made sure my filament is of good quality. What could be causing this problem, and how can I troubleshoot and fix it?
Best Answer by Robin_13:
Check the extruder teeth are clean and that the grub screws are tight.  Also that it is aligned properly with the filament.
Publié : 05/11/2023 5:37 pm
Robin_13
(@robin_13)
RE: issue with my Prusa i3 MK3 3D printer
Publié : 09/11/2023 11:01 pm
1 personnes ont aimé
Afrasiab Sajid
(@afrasiab-sajid)
Membre
Thanks a lot.
Publié : 14/11/2023 10:09 am
