Is it possible to add an extra shell perimeter above a certain height using Prusa slicer
Yes
Yes. Right click on the object and select add modifier.
Error
Attachment removed
I get an error with that when try to import:
ConfigBase::set_serialize() failed
Thanks
Thanks
Height Range Modifier
BTW I forgot there is also Height Range Modifier.
I suspect the error is because I'm using a custom printer.
That
That would do it!
