Infill shifted
Trabi_601
(@trabi_601)
Infill shifted
I try to print his battery holder but the infill is shifted to the left. On the right hand you can see that it is even not a static shift, but the gap increases.
Any idea what is wrong?
Material: Prusa PLA, printer MK3S, latest firmware.
Thanks for hints!
could somebody help me.
Respondido : 26/02/2021 7:45 pm
Dan Rogers
(@dan-rogers)
RE: Infill shifted
The holes are shifted as well.  The first layer shows shifting as well all across the surface.  Think about whether your belt for X motion is tight enough, and check the grub screws on the motor pulley for being tightened in the proper order.
Respondido : 26/02/2021 9:58 pm
Trabi_601
(@trabi_601)
RE: Infill shifted
Thanks a lot. I have tighten the belts and now everything is perfect!
Respondido : 27/02/2021 8:08 pm
1 les gusta
