infil separating from the endge of the print
I'm having this weird issue with eSun PLA+ filament, for some weird reason the infil patten starts separating from the walls and over time the things goes to mess.As it separates, it starts to curve, and you get this curved end rather than pointing endge that touches the wall.
Strangely, for the first 4-5mm of print (which is a lot of layers), the print goes all OK. Not sure what is the issue here, hardware, temperature settings or something else?
I'm using CURA and printed it on 210/60 temp with 0.6 nozzle (0.4 layer height with adaptive layers, but that didn't kick in yet)
Ce sujet a été modifié il y a 3 years par vkovanovic
Publié : 07/03/2023 6:01 am
