Inconsisten first layer extrusion with large prints
dylenthomas
(@dylenthomas)
Utenti
I have a Prusa Mk3s+ using a smooth PEI sheet for the print bed.
When I print something large (about 1/4 of the bed SA) I get uneven extrusion in predictable spots (around the middle of the bed is low extrusion and the outer edges look good, but when I print smaller parts in the middle of bed the extrusion looks great so I am not sure what is going on), which also happens in the same exact spot when I have two parts that cover a large SA. The perimeters and brim all look good no matter what I print on every part of the bed, so it is only the solid infill. The problem fixes itself after the first layer or two and the strength/reliability of the prints don't seem to be compromised by this, so its just mildly annoying. This also started a few days ago and I haven't had issues like this before.
My two thoughts are either firmware or a warped bed, but I am a novice with 3d printing so I could be wrong. I was wondering if anyone has experienced something similar or has any ideas on what could be causing this. Thank you.
Best Answer by Diem:
You are posting in the wrong part of the forum - Mods, can we move this?
I presume you have been following the built-in procedure:
   https://help.prusa3d.com/article/first-layer-calibration-i3_112364
If there are remaining levelling issues go to:
   https://help.prusa3d.com/article/bed-level-correction_2267
Remember that you will have to revisit the basic levelling every few months as your nozzle wears and each time you replace one.
Postato : 28/09/2024 11:51 pm
elsabeth
(@elsabeth)
Utenti
RE: Inconsisten first layer extrusion with large prints
A warped print bed can lead to inconsistent nozzle distances, affecting extrusion. Check the bed for flatness, especially around the middle. You might want to re-level the bed, ensuring that the nozzle height is consistent across the entire surface.
Postato : 29/09/2024 9:17 am
MODs: please move this thread
Postato : 29/09/2024 11:24 am
dylenthomas
(@dylenthomas)
Utenti
Well the thing is when I do the z offset calibration print it looks good all over the bed. The leveling looks great on smaller prints, but the problem only occurs on first layer solid infill with larger prints. I will still redo the first layer cal and try the bed level correction and update, thank you for the responses.
Questo post è stato modificato 1 year fa da dylenthomas
Postato : 29/09/2024 1:39 pm
dylenthomas
(@dylenthomas)
Utenti
The bed level correction worked, thank you for the suggestion.
Postato : 29/09/2024 5:41 pm
