How to print with glass
Pagina 4 / 12
ssill2
(@ssill2)
RE: How to print with glass
with 2.3.1 the same spikes appear.
Postato : 05/06/2021 3:47 pm
Ringarn67
(@ringarn67)
Posted by: @ssill2
The spikes comes from "Detect Thin Walls"!
Why? I don't know!
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Postato : 05/06/2021 4:08 pm
ssill2
(@ssill2)
@ringarn67
oh interesting.  I'll uncheck that and see.
Postato : 05/06/2021 4:09 pm
ssill2
(@ssill2)
yes you are correct.  unchecking that makes them go away.  Good to know!  Thanks!
Postato : 05/06/2021 4:10 pm
ssill2
(@ssill2)
so before I try massive number of perimeters I'm trying with aligned rectilinear at 315 deg, which is the angle the original author of the printing with glass I article I started with used, but in S3D it's done as -45 deg.  at .6mm the print still looks reasonably clear, more reasonable than the previous value.  at the same height, the infill starts being filled in from the middle, and not from the left wing tip as at the start of the model.  I don't see any way to control that in prusa slicer.
Anyway, it's doing height .8mm right now and it still looks pretty clear, so I'll let it go.  I think the all perimeters thing might give it some bizarre optics.  I'll see how this turns out though.  Even with 100% infill, this model only uses about 7g of filament so I can try this many many more times lol
Postato : 05/06/2021 4:26 pm
Utenti
I have about 9-10 rolls of transparent PETG.  If you nail down the settings for Batman logo, I will do comparison prints of each.
Postato : 05/06/2021 4:30 pm
ssill2
(@ssill2)
@cwbullet
I think I'm close with this latest one.
Here's what it's looking light at 1mm z so far.
I'm anxious to try this some other transparent petg filaments like the Taulman T-Glase and some sainsmart I have.  265C is too hot for the T-Glase though, tried it briefly last night, so I'll have to lower it slightly, but leave all the other settings.  Haven't tried the sainsmart pro petg pink transparent I have.   But in theory once I get this figured out it should work for most transparent filaments just adjusting for temperature I would think.
Postato : 05/06/2021 4:37 pm
Swiss_Cheese
(@swiss_cheese)
I have some other suggestions but I'll be out, believe it or not at meetings most of the day, when I return I'll write out the other suggestions.
Enjoy
Swiss_Cheese
The Filament Whisperer
Postato : 05/06/2021 4:40 pm
1 persone hanno apprezzato
ssill2
(@ssill2)
Ok, since this seems to be working now, here's the latest version of the .3mf.  Again, this is being done with AtomicFilaments clear petg, so you might have to lower the temp from 265C.  265C is the top of the range on the spool label for this stuff.  After this completes I might try with sunlu clear and the other ones I mentioned above.  I could see this looking pretty cool with colors.
Attachment removed
Postato : 05/06/2021 4:41 pm
ssill2
(@ssill2)
@swiss_cheese
As always I'll wait with bated breath! 🙂
Postato : 05/06/2021 4:42 pm
Utenti
@ssill2
Ok.  I have one roll of each of the clear PETGs.
Postato : 05/06/2021 4:44 pm
ssill2
(@ssill2)
@cwbullet
this thing is at 50% done, 1.3mm high so far.   I still looks pretty good.
Postato : 05/06/2021 4:46 pm
ssill2
(@ssill2)
@cwbullet
AnnieR
(@annier)
I've been able to get almost clear pieces by using transparent ABS and doing 100 percent infill and after the print is done, stroking it gently with a mop brush dipped in acetone.
Postato : 05/06/2021 4:50 pm
ssill2
(@ssill2)
@annier
yeah someone else mentioned the clear abs as well.  I'm trying to avoid printing with ABS, but I'll definitely keep that in mind if I need to do something that's needs a higher temp.  PETG has the advantage of not having all the fumes and not needing to be hooked up to ventilation.
Postato : 05/06/2021 4:52 pm
Utenti
@annier
What brand of ABS are you using?
Postato : 05/06/2021 4:54 pm
ssill2
(@ssill2)
Wow, the Taulman T-glase is looking awesome!  It's nearly done,  just had to lower the temp to 245C
Postato : 05/06/2021 8:10 pm
ssill2
(@ssill2)
Not bad!
Postato : 05/06/2021 9:07 pm
2 persone hanno apprezzato
ssill2
(@ssill2)
Now printing in Sainsmart pro PETG translucent pink.
Postato : 05/06/2021 9:25 pm
Swiss_Cheese
(@swiss_cheese)
@annier
Have you tried, or do you use acetone vapor smoothing? you keep talking about applying with a paint brush (Mop brush) do you find the results are better this way compared vapor smoothing, or are you going for a different look then vapor smoothing offers?
Also could you post some images of the results of using the Mop brush? if you can, would it be possible to see both successes and failures of this technique to compare?
I currently have only vapor smoothed and have had both good and bad results depending on the model and also how I orient it in the chamber for smoothing.
Thanks in advance
Swiss_Cheese
Postato : 05/06/2021 10:31 pm
Pagina 4 / 12
