How to optimizing Gcode?
SergePix
(@sergepix)
Hello,
I have a lot of numbers to print on a tablet. The numbers are printed randomly which takes a lot of time to print. The print head is moving from one side to the other.
I don't understand why the printing is not done in sequence.
Is there a way to optimize the way of printing?
Publié : 07/01/2025 10:28 pm
Robin_13
(@robin_13)
RE: How to optimizing Gcode?
Try the classic mode for slicing.  I saw this issue with a print that had a large amount of movement.  Classic cut the time down as well.
Need to enable Normal or Advanced and in the Print settings, under Layers and perimeters, you can change this.
Publié : 17/02/2025 10:23 pm
