How Make a Printed Part Stronger?
sunrise747
(@sunrise747)
I am printing the part shown in ASA because it is used outdoors.  It is 3mm thick, 85mm long and 50 mm wide.   I am having trouble with the part breaking at the joint indicated by the red circle and dotted line.  There is approximately 12 lbs of weight (force) intermittently pressing against the inside wall indicated by the blue lines.  I have increased the outer layer thickness but it still breaks after a few weeks of use.  Any suggestions would be much appreciated!
Este debate ha sido modificado el hace 4 years por sunrise747
Respondido : 22/12/2021 12:05 am
Swiss_Cheese
(@swiss_cheese)
RE: How Make a Printed Part Stronger?
@sunrise747
Export the .3mf project file from PrusaSlicer, Zip the project and post it here and I will take a look and see if I can help.
Note: if the project is not Zipped the forums file server will not allow it to be posted.
Regards
Swiss_Cheese
The Filament Whisperer
Respondido : 22/12/2021 1:55 am
sunrise747
(@sunrise747)
Thank you!
FC 4X4+Weep
Respondido : 22/12/2021 2:11 am
Swiss_Cheese
(@swiss_cheese)
@sunrise747
Try this and see how it preforms. I moved the seams, the majority of them were being placed in the area you pointed out as the weak area, Changing the orientation on the bed was part of this. I also added 2 more perimeters and adjusted them for proper overlap. I changed the modifier in the problem area and made it a solid infill.
BClip T9 4X4 + Weep Holes v4_Swiss.Zip
I would expect better performance. Let us know how it goes.
Good Luck
Swiss_Cheese
Respondido : 22/12/2021 4:05 am
sunrise747
(@sunrise747)
SC -  Thank you so very much!  That was super kind of you.  Once I have some real-world results I'll let you know how it goes.
Respondido : 22/12/2021 11:06 pm
Swiss_Cheese
(@swiss_cheese)
@sunrise747
your welcome, I'm looking forward to seeing how it works out.
Regards
Swiss_Cheese
Respondido : 23/12/2021 12:37 am
