					                		How do I solve the &quot;spider web&quot; little thin hairs on my PLA print - How do I print this? (Printing help)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/</link>
                <lastBuildDate>Sat, 11 Apr 2026 21:06:07 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/paged/2/#post-749269</link>
                        <pubDate>Fri, 09 May 2025 11:16:21 +0000</pubDate>
                        <description><![CDATA[I use a Sunlu dryer. I&#039;m relatively new to 3D printing, and my experience with the Sunlu S2 is that it doesn&#039;t completely dry the entire spool of filament.
Let’s say I have a 4-hour print j...]]></description>
                        <content:encoded><![CDATA[<p class="" data-start="129" data-end="284">I use a Sunlu dryer. I'm relatively new to 3D printing, and my experience with the Sunlu S2 is that it doesn't completely dry the entire spool of filament.</p>
<p class="" data-start="286" data-end="555">Let’s say I have a 4-hour print job. During the first hour, I get no webbing at all. But as more filament is used and I go deeper into the spool, I start to see slight webbing. To me, this suggests that the heat from the dryer isn't reaching deep enough into the spool.</p>
<p class="" data-start="557" data-end="905">One possible solution might be to put holes in the sides of your spools to help air or heat penetrate better—but I don’t want to do that, since I’m using modified cardboard spools in a AMS, and cutting into them could create dust or weaken them. I’ve also tried running a 24-hour drying cycle, but the issue still shows up as I get deeper into the filament.</p>
<p class="" data-start="907" data-end="1113">If you're only doing short prints, I’d suspect it’ll be fine. Personally, as long as it’s not affecting the quality of the print itself, the webbing is easy enough to remove with your fingers or a heat gun.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>dazzauk83 3</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/paged/2/#post-749269</guid>
                        <title>RE: How do I solve the &quot;spider web&quot; little thin hairs on my PLA print</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/paged/2/#post-718061</link>
                        <pubDate>Mon, 05 Aug 2024 03:07:03 +0000</pubDate>
                        <description><![CDATA[Be careful on smaller models. Too much heat can melt the model. I&#039;d use a needle nose file of various sizes to avoid warping and melting the model, especially on miniature sized models and w...]]></description>
                        <content:encoded><![CDATA[<p>Be careful on smaller models. Too much heat can melt the model. I'd use a needle nose file of various sizes to avoid warping and melting the model, especially on miniature sized models and what not.  Just learned the hard way a heat gun acts fast so you gotta keep it moving at different lengths.  Every model is different, but the general rule is minimal heat per time per filament (PLA).</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Robert5185</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/paged/2/#post-718061</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/paged/2/#post-629421</link>
                        <pubDate>Fri, 09 Dec 2022 20:35:28 +0000</pubDate>
                        <description><![CDATA[@fuchsr … Thanks for the info about the fan.. must have missed that in the specs.. .. Don’t think Sunlu will replace my S2 (I’m awaiting word) but with the fan, the PrintDry Pro will be my n...]]></description>
                        <content:encoded><![CDATA[<p>@fuchsr … Thanks for the info about the fan.. must have missed that in the specs.. .. Don’t think Sunlu will replace my S2 (I’m awaiting word) but with the fan, the PrintDry Pro will be my next purchase. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Crab</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/paged/2/#post-629421</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/paged/2/#post-629213</link>
                        <pubDate>Wed, 07 Dec 2022 21:57:16 +0000</pubDate>
                        <description><![CDATA[FWIW, I bought a PrintDry Pro a few months ago when I caught it on sale. I have to say it’s been effective and reliable at drying the various filaments I’ve thrown at it.PrintDry is based in...]]></description>
                        <content:encoded><![CDATA[<p>FWIW, I bought a PrintDry Pro a few months ago when I caught it on sale. I have to say it’s been effective and reliable at drying the various filaments I’ve thrown at it.</p><p>PrintDry is based in Canada so maybe that’s a good thing for you @crab ? Btw, good on you for coming back to this thread to report your experience with the other dryer you had. I struggled with the $$$ for the PrintDry as well but all the terrible reviews of the units similar to what you tried kept me from experimenting with one. I guess the old saying, ‘buy once, cry once’ is appropriate.</p><p>I recently received an email from them saying they were having a Black Friday / Cyber Monday sale, so maybe you can still catch a sale between now and Christmas? Worth checking out. </p><p>Good luck!</p><p>Cheers</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>RandyM9</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/paged/2/#post-629213</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/paged/2/#post-629199</link>
                        <pubDate>Wed, 07 Dec 2022 21:04:58 +0000</pubDate>
                        <description><![CDATA[PrintDry system. I’d prefer it to have some form of fan.The PrintDry has a fan. It&#039;s humming along right behind me…]]></description>
                        <content:encoded><![CDATA[<blockquote><p> PrintDry system. I’d prefer it to have some form of fan.</p></blockquote><p>The PrintDry has a fan. It's humming along right behind me…</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>FoxRun3D</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/paged/2/#post-629199</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/paged/2/#post-629196</link>
                        <pubDate>Wed, 07 Dec 2022 20:51:29 +0000</pubDate>
                        <description><![CDATA[@Swiss_Cheese. Grin.. had to come back to admit to the ‘crappy’ Sunlu S2 that now has died after about 10 uses in 6 months. There are a number of issues with many of these off-shore (to us i...]]></description>
                        <content:encoded><![CDATA[<p>@Swiss_Cheese. Grin.. had to come back to admit to the ‘crappy’ Sunlu S2 that now has died after about 10 uses in 6 months. There are a number of issues with many of these off-shore (to us in NA) products.. I swear they don’t do any testing or QA on the units. The SunLu has a humidy sensor that not only does not work.. but the humidy displays values or images that aren’t characters  in any language. And this is shipping firmware. Then when I contact Sunlu they say to go to my local distributor; so you are now at the mercy of a local distributor to provide any service.. and they deal with so many brands..  I’ve contacted my local distributor but messages are ping-ponging back and forth and likely nothing will happen. What I consider maybe the best 3dPrinter co in canada, VoxelFactory, doesn’t even seem to deal in anything other than the PrintDry system. I’d prefer it to have some form of fan.. but it does look like the only reputable brand that one might be able to buy from Canada. Not that I don’t think Swiss_Cheese could have given more info to base his decision.. but his advice seems solid in hindsight.. </p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/paged/2/#post-629196</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/#post-609569</link>
                        <pubDate>Sat, 11 Jun 2022 16:41:49 +0000</pubDate>
                        <description><![CDATA[I would like to thank everyone for their inputs. Obviously, there is a lot for me to think about.]]></description>
                        <content:encoded><![CDATA[<p>I would like to thank everyone for their inputs. Obviously, there is a lot for me to think about.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>bastianga</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/#post-609569</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/#post-609542</link>
                        <pubDate>Sat, 11 Jun 2022 08:03:21 +0000</pubDate>
                        <description><![CDATA[The oozing you mention does actually occur when the extruder is heating up.This too can be a symptom of wet filament - some being pushed out by steam.I use a food dehydratordidn&#039;t do much re...]]></description>
                        <content:encoded><![CDATA[<blockquote><p>The oozing you mention does actually occur when the extruder is heating up.</p></blockquote><p>This too can be a symptom of wet filament - some being pushed out by steam.</p><p>I use a food dehydrator:</p><p>https://www.amazon.co.uk/HOMCOM-Dehydrator-Adjustable-Temperature-Control/dp/B01N8OWBLQ/ref=sr_1_5?crid=YLPBZLC5NVD8&amp;keywords=dehydrator&amp;qid=1636119085&amp;sprefix=dehy%2Caps%2C73&amp;sr=8-5</p><p>I didn't do much research - just picked one that used up the remaining credit on a gift-card.</p><p>You can either snip out the bottom of a couple of trays to make room for a filament roll or do what I did and print a tall spacer.  A translucent PETG spacer has worked OK for me so far...</p><p>Attached are files for the spacer. dryerinsert should fit a Mini, print three and glue together to make a spacer.  dryerinsert1 fits an i3, print two and glue together.  </p><p><a href="https://forum.prusa3d.com/wp-content/uploads/wpforo/default_attachments/1636122938-dryerinsert.zip">dryerinsert</a></p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2021/12/dryerinsert1.zip">dryerinsert1</a></p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/#post-609542</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/#post-609531</link>
                        <pubDate>Sat, 11 Jun 2022 04:32:25 +0000</pubDate>
                        <description><![CDATA[You may already be a winner.  ;-)Food dehydrators also work quite well on damp 3d print filament.We have one of those Ninja Cookers which has a dehydrate mode.  If I have a suspected damp fi...]]></description>
                        <content:encoded><![CDATA[<p>You may already be a winner.  ;-)</p><p>Food dehydrators also work quite well on damp 3d print filament.</p><p>We have one of those Ninja Cookers which has a dehydrate mode.  If I have a suspected damp filament spool I'll just put it in the Ninja, set it to dehydrate at about 120F/49C and let it run overnight.</p><p>People have reported having good luck in a regular full-size ELECTRIC oven, set to a low keep-warm temperature, but there have been reports of ruined filament when trying to dry it in a gas oven.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>jsw</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/#post-609531</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/#post-609523</link>
                        <pubDate>Sat, 11 Jun 2022 01:31:02 +0000</pubDate>
                        <description><![CDATA[@crabPlease allow me to provide my professional opinion as to what makes a good dryer. This would be a dryer that is capable of drying PA (Nylons &amp; the like),PC&#039;s,ABS, PETG and the like ...]]></description>
                        <content:encoded><![CDATA[<p>@crab</p><p>Please allow me to provide my professional opinion as to what makes a good dryer. This would be a dryer that is capable of drying PA (Nylons &amp; the like),PC's,ABS, PETG and the like probably in that order as PETG and PLA are in the lower spectrum of the list, however still very much need drying.</p><p>Now just to be clear In the past a legitimate modified food dehydrator, was more then adequate to handle the needs of these filament types. Frankly they are to this day easy enough to modify for filament use, However there are a couple of commercially available alternatives if your don't have the time or desire to build/modify one yourself. If your already willing to spend  $80 US dollars or more on a Sunlu that frankly is lacking, and it is, spend the $189 USD on a print dry, or equivalent because it just gets the  job done, no matter what, it does, it doesn't matter where you live or what your humility is it works. As would a  self built food dehydrator, you can contest this to your hearts desire you will find my information to be true. I have spent the time and the money already. If you chose to experiment and play around with your money, then by all means do so, but you are wasting your money, as someone that has learned better through time and experience is letting you know </p><p> </p><p>The SUNLU system and it's like were not worth a crap, you can spend your money on them if you like, however  once you own a real, and effective drying system you won't suggest them again in good conscience.</p><p> </p><p>I say Whatever, I don't care to continue this conversation.</p><p> </p><p>Say what you like.</p><p> </p><p>Swiss_Cheese</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Swiss_Cheese</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-do-i-solve-the-spider-web-little-thin-hairs-on-my-pla-print/#post-609523</guid>
