					                		Having problems with overhangs (?) , on every type of plastic - How do I print this? (Printing help)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/</link>
                <lastBuildDate>Fri, 12 Jun 2026 08:37:19 +0000</lastBuildDate>
                        <title>RE: Having problems with overhangs (?) , on every type of plastic</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-670623</link>
                        <pubDate>Fri, 25 Aug 2023 07:12:28 +0000</pubDate>
                        <description><![CDATA[This helped, I found a standard prusa fan-duct but for two print fans, the prints are flawless now. Thank you! :)]]></description>
                        <content:encoded><![CDATA[<p>This helped, I found a standard prusa fan-duct but for two print fans, the prints are flawless now. Thank you! :)</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>mAtoOo</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-670623</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666456</link>
                        <pubDate>Sun, 30 Jul 2023 10:29:08 +0000</pubDate>
                        <description><![CDATA[I must say I&#039;ve tried a few new and improved fan ducts and found that none of them did any better than stock, and often worse… I suspect that there&#039;s always the edge case or two were those &quot;...]]></description>
                        <content:encoded><![CDATA[<p>I must say I've tried a few new and improved fan ducts and found that none of them did any better than stock, and often worse… I suspect that there's always the edge case or two were those "improved" designs may yield better results, I just never encountered one in my practice.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>FoxRun3D</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666456</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666447</link>
                        <pubDate>Sun, 30 Jul 2023 09:39:27 +0000</pubDate>
                        <description><![CDATA[I would suspect cooling. Try a standard prusa fan duct]]></description>
                        <content:encoded><![CDATA[<p>I would suspect cooling. Try a standard prusa fan duct</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>JoanTabb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666447</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666436</link>
                        <pubDate>Sun, 30 Jul 2023 08:33:27 +0000</pubDate>
                        <description><![CDATA[Is that an aftermarket Fan duct? often modified fan ducts perform poorly.Yes it is - this one:the benchy seems to help with the overhangs significantly.  Is this due to poor belt tension (I ...]]></description>
                        <content:encoded><![CDATA[<ul><li><em>Is that an aftermarket Fan duct? often modified fan ducts perform poorly.</em><ul><li>Yes it is - this one: https://www.printables.com/model/63279-dual-fan-for-mk3s-extruder/comments/99501</li></ul></li></ul><p>Turning the benchy seems to help with the overhangs significantly.  Is this due to poor belt tension (I tried adjusting these twice before writing this post , I guess it was not enough?) or is this due to cooling? There still seems to be a very small artefact at the beginning part of the bow of the ship.<br /><br /><strong>Picture:</strong><br /><a href="https://forum.prusa3d.com/wp-content/uploads/2023/07/20230730_102810-scaled.jpg"><img class="alignnone size-medium wp-image-155327" src="https://forum.prusa3d.com/wp-content/uploads/2023/07/20230730_102810-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666436</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666125</link>
                        <pubDate>Fri, 28 Jul 2023 16:09:41 +0000</pubDate>
                        <description><![CDATA[Is that an aftermarket Fan duct? often modified fan ducts perform poorly.    I was looking to see if the fan duct was low enough, and that looks ok... do you have a standard prusa Fanduct th...]]></description>
                        <content:encoded><![CDATA[<p>Is that an aftermarket Fan duct? often modified fan ducts perform poorly.    I was looking to see if the fan duct was low enough, and that looks ok... do you have a standard prusa Fanduct that you can try? <br />Can you turn the Benchy 90 degrees so that the bows are pointing in a different direction, and see if the results change  there may be poor cooling in some areas... </p>
<p>If you need to print a prusa fan duct, you can print PETG without a fan duct if necessary. petg is not as good as |ASA but for a test it should be fine</p>
<p>good luck, <br />Joan</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666125</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666107</link>
                        <pubDate>Fri, 28 Jul 2023 13:43:43 +0000</pubDate>
                        <description><![CDATA[Note: Ignore the background , that is obviously not my main print room. It is there just for testing purposes :p]]></description>
                        <content:encoded><![CDATA[<p><a href="https://forum.prusa3d.com/wp-content/uploads/2023/07/20230728_152933.jpg"><img class="alignnone size-medium wp-image-155302" src="https://forum.prusa3d.com/wp-content/uploads/2023/07/20230728_152933-600x500.jpg" alt="" width="600" height="500" /></a><br />Note: Ignore the background , that is obviously not my main print room. It is there just for testing purposes :p</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666107</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666098</link>
                        <pubDate>Fri, 28 Jul 2023 13:01:21 +0000</pubDate>
                        <description><![CDATA[Could you please send a picture similar to this, of your prusa with  Revo. Note, this is not a prusa, but it&#039;s the only printer that I have a Revo on!regards Joan]]></description>
                        <content:encoded><![CDATA[<p>Could you please send a picture similar to this, of your prusa with  Revo. <br /><br />Note, this is not a prusa, but it's the only printer that I have a Revo on!</p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2023/07/Revo.jpeg"><img class="alignnone size-medium wp-image-155300" src="https://forum.prusa3d.com/wp-content/uploads/2023/07/Revo-600x500.jpeg" alt="" width="600" height="500" /></a></p><p><br />regards Joan </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666098</guid>
                        <title>Having problems with overhangs (?) , on every type of plastic</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666096</link>
                        <pubDate>Fri, 28 Jul 2023 12:43:21 +0000</pubDate>
                        <description><![CDATA[Hello! To start off , I rock a MK3S+ with a REVO Six hotend , and dual print fan setup. Until recently everything was working flawlessly but after , a rather hard, nozzle change (where the n...]]></description>
                        <content:encoded><![CDATA[<p>Hello! <br /><br />To start off , I rock a MK3S+ with a REVO Six hotend , and dual print fan setup. Until recently everything was working flawlessly but after , a rather hard, nozzle change (where the nozzle got stuck because of a serious clog and I had to remove it with pliers), issues started to occur on my prints, especially with overhangs. <br /><br />I have tested these on both overhang test prints and benchies where I tried to adjust the print and bed temperatures, print fan speeds , print speeds (this helped a lot compared to the others), and PID and overall calibration with no , or limited success. I tried different nozzles too, but it was not the issue in them - this was just overthinking.<br /><br />I had partial success after straightening the Z-axis (making sure they are even), (the picture with only one PET-G benchy)<br /><br />These overhang issues are reoccuring on every filament I print with - PLA, PET-G and ASA.<br /><br />Thank you, I will value your input/help ! :)<br /><img src="https://i.imgur.com/axq9hZf.jpg" alt="PET-G Benchies - same nozzle, different speeds" width="2184" height="1229" /><img src="https://i.imgur.com/PPsIZgJ.jpg" alt="PET-G benchy - after straightening the Z-axis" width="1483" height="2636" /><img src="https://i.imgur.com/sHnxl5J.jpg" alt="PLA Benchies - same gcode two different 0.4mm nozzles" width="2635" height="1482" /></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/having-problems-with-overhangs-on-every-type-of-plastic/#post-666096</guid>
