Hatchbox ABS Printing Issue
Hello,
New to 3d printing and so far have just printed PLA on a mk3 with mostly success. Purchased a roll of black Hatchbox so that I could print the updated extruder R3 but running into issues. From what I have read I think this is over extrusion? Any ideas or should I try a different ABS roll/brand? I used the generic ABS settings in Slic3r but changed the bed temp to 80 and set the extruder temp to match what is printed on the section of the part. Im also printing in a Lack enclosure.
Thanks,
Mike
Re: Hatchbox ABS Printing Issue
Can you provide an STL model or an Gcode? I try to print it in my mk3.
Personally I am using 100/110°C heatbed 250°C nozzle, enclosure and from this time I am happy with my ABS prints.
University: MK2S upgraded to MK3 with MMU2.0
Home: MK3
Materials: ABS; ASA; PETG; PET; PLA; Nylon; Nylon Carbon; CPE;
SW: Freecad 0.18; Slicer PE And still generating more troubles than whole forum together.
It looks like you need a bit of fan on those overhangs and more fan than what you are using on bridges. As you are using an enclosure try using 20% fan. With a bit of luck it should take it without warping.
Regards,
Martin
Martin Wolfe
