Grouping a Hole Doesn't Cut It (Tinkercad)
Wingsy
(@wingsy)
I've looked for Tinkercad forums and what I've found is pretty sparse, so I'm asking here.
I'm trying to make a gear for a ball chain. When I group a sphere (as a hole) with a flat cylinder the hole doesn't cut out the cylinder. I've elevated one of the spheres to the edge of the cylinder so you can more easily see the problem.
What am I doing wrong?
Opublikowany : 03/06/2018 9:49 am
Wingsy
(@wingsy)
Re: Grouping a Hole Doesn't Cut It (Tinkercad)
OK, false alarm. I found the problem.
I had inadvertently duplicated the cylinder and when I grouped the holes with the cylinder it still had the 2nd cylinder still there, ungrouped.
Opublikowany : 03/06/2018 10:12 am
Hi Wingsy,
thanks for admitting the oversight,
it may help other people in a similar situation,
I have had similar experiences with 123D design
Opublikowany : 03/06/2018 11:17 am
