Fine detail printing
Hello!
Not sure how I can print the fine text in the attached file. I now have a .25mm nozzle, but when I slice it with the nozzle changed in the Extruder setting, it still shows that some detail will not be printed. Is there anything else I can do?
Thanks!
Attachment removed
Posted : 01/12/2020 12:50 am
RE: Fine detail printing
I don't know if this is the answer your looking for, however if you go to Print Settings/ Advanced/ XY Size Compensation and set it to 0.1 or 0.15 it will produce a nice result with even a 0.4 nozzle.
I hope this helps, good luck
The Filament Whisperer
Posted : 01/12/2020 1:58 am
You can use "Detect thin walls" which you will find under "Print settings".
Posted : 01/12/2020 10:12 am
Topic starter
answered:
The XY Size Compensation adjustment worked - Thanks!
Posted : 02/12/2020 1:29 am
Glad I could help.
Posted : 02/12/2020 1:37 am
