ESUN PETG Print Settings
Page 2 / 2
ssill2
(@ssill2)
not perfect
here's the thing in duramic3d silver PETG. I hadn't noticed the small imperfection when I printed in white.
I mean honestly this should be ok.  I'm sure swiss_cheese could get this across the finish line lol
Publié : 12/10/2021 12:23 pm
Membre
Filament
Duramic Silver PETG is a good filament.  It is not the only one.  I have also used the following:
  1. Hatchbox Silver PETG
  2. Inland Silver PETG
  3. Matterhacker Silver PETG
  4. eSun Silver PETG
  5. Push Plastics Silver PETG
My favorite is Duramic or Push Plastics but you get good results with all of the ones listed above.  I hope Prusa releases a silver Prusament.
Publié : 12/10/2021 1:58 pm
ssill2
(@ssill2)
silver
I've been happy with the duramic silver.  I have a few other spools of there stuff.  Pretty good results with it.
Publié : 12/10/2021 2:11 pm
Rocky79
(@rocky79)
Thank you
Thank you for your detailed reply. I appreciate it
Publié : 14/10/2021 6:19 am
Rocky79
(@rocky79)
Nice work
Thank you for doing this. What extrusion multiplier are you using for this print?
Also, your ironing setting looks very nice, are you using the default settings?
Posted by: @ssill2
Publié : 14/10/2021 6:23 am
ssill2
(@ssill2)
RE: attempt4
I've attached the most recent version.  It's the version used to print that in duramic silver.
It's not perfect.  This is only different from attempt 3 in temp.  I had transposed the first layer temp as 254 when I meant to 245.  Again, this printer has a steel nozzle so that temp is a little higher than it would be for brass.
Posted by: @rocky79
Posted by: @ssill2
Publié : 14/10/2021 11:07 am
2 personnes ont aimé
Rocky79
(@rocky79)
bed temp
Thank you.
I understand the first layer bed temp is important but why does it need to go up to 90C for other layers?
Do you know the rational behind it?
Publié : 14/10/2021 3:11 pm
Rocky79
(@rocky79)
settings mods
Also, can you please explain the reason behind reducing the minimum shell thickness to 0.5mm?
and why the ensure vertical shall thickness is not checked?
Publié : 14/10/2021 3:18 pm
ssill2
(@ssill2)
default for prusament
the bump to 90 is the default for prusament petg. I think you could probably do 85 for all and be fine.
Posted by: @rocky79
Thank you.
Publié : 14/10/2021 3:21 pm
ssill2
(@ssill2)
shell thickness
I had to mess with those to eliminate the gaps in the sliced model.  go back to your original and slice it.  look at each layer in in the sliced output. you'll see gaps.  I toyed around with extrusion widths and the shell thickness to eliminate the gaps.
Posted by: @rocky79
Publié : 14/10/2021 3:23 pm
Rocky79
(@rocky79)
Slice of bread
Got it. Well done mate. I really appreciate your effort.
Posted by: @ssill2
Posted by: @rocky79
Publié : 14/10/2021 4:13 pm
Constantin
(@constantin-2)
RE: ESUN PETG Print Settings
I know this is an old thread - but I still wanted to express my gratitude. Thanks to you, I notice that Prusa changed their extrusion multiplier to 1.0, over the last year, meaning that printing quality got heavily compromised on my older MK3S+. Thank you 🙂
Publié : 18/12/2024 9:32 am
Page 2 / 2
