Damaged in bottom printing
liubie
(@liubie)
I have a problem with printing and I could not find a reason for it. Damaged parts appear at the bottom of the shapes (as in a video)
Postato : 09/05/2021 11:50 pm
RE: Damaged in bottom printing
The second example is pretty clear cut. Spidy's chin is an overhand, and printers haven't learned yet how to lay down layers in thin air, so you need supports.
The first one is not clear to me from the angle of the camera but most likely also an overhang that requires supports.
Postato : 10/05/2021 12:44 am
It's a combination of cooling and overhang angles. Rotating the part with the steepest overhangs towards the front of the print so that cooling air hits the surface being printed first. If air has to flow around the part to cool the overhang, the print will suffer.
Questo post è stato modificato 4 years fa da --
