Cutting a hole into a hole with Tinkercad - is that possible?
Unicorn3D
(@unicorn3d)
I had the problem that I needed a cylinder section (so a pie shaped object) to shave off some material from an auto generated object.
So I wanted to create the intersection of two holes - which isn't directly possible with Tinkercad.
After banging my head for two hours trying to get that done I finally realized that you can model the hole first as a solid object and then change it into a hole. ==> Problem solved.
Just leaving this here in case someone is running into a similar problem.
Posted : 11/02/2024 11:39 pm
