Can you change infill half way thru print
Jerry S
(@jerry-s)
The bottom of my cylinder needs to be stronger. I changed the infill from 15% to 40% but it's a waste to continue the rest of the part at 40%. Can I change the infill back to 15% after about the first 1/2 inch of height?
Opublikowany : 29/03/2021 2:56 pm
Jerry S
(@jerry-s)
RE: Can you change infill half way thru print
file for initial post
Opublikowany : 29/03/2021 3:06 pm
Yes just use a modifier.
https://help.prusa3d.com/en/article/modifiers_1767
Opublikowany : 29/03/2021 3:16 pm
