Biting Dragon from Cults 3D
I am trying to print this biting dragon from Cults 3D: https://cults3d.com/en/3d-model/art/dragon-mordedor-ergio959
The screenshot shows where I am having an issue: a small piece where the two head halves come together and make a connection to the main body. All of my prints are failing in this small section while the rest of the head seems ok.
Does anyone have advice on what to change in the settings to make sure this prints better? I don't mind taking a lot of extra time. Thanks.
RE: Biting Dragon from Cults 3D
I got it. I decreased the layer height from 0.15 mm to 0.1 mm, increased first layer height from 0.2 mm to 0.3 mm, and added a brim (outer only, 2 mm wide, 0.1 mm gap). I'm not sure if it solved it with 1 of those things, 2 of those things, or all 3, but it worked this time.
