Best way to glue two parts together with textured surface?
nim108
(@nim108)
Because of a rather challenging model that would have required a ton of supports, I split it into two in Meshmixer and printed it (in PLA) on my powder coated textured sheet (with each face on the bed). What is the best way to combine them? Sand the textured surfaces and superglue? Would anything else work better? What about epoxy or hot glue? Thanks.
Posted : 26/05/2020 11:29 pm
quietmesh
(@quietmesh)
RE: Best way to glue two parts together with textured surface?
I would definitely go for epoxy and no sanding.
FWIW If you are using PrusaSlicer you can cut the model there.
Posted : 27/05/2020 3:37 am
