Bad 2nd Layer (edited with images)
Please help me adjust the setup for this print.
I have three attempts at this project. Each time the first layer comes out nicely. Each time the second layer starts nicely then, stops laying down an even layer.
another piece on the build plate
0.10 mm height
Amazon Basics PETG
First layer 220° C
Other layers 230° C
>>> All of life is learning <<<
i3 MK3 Kit w/ S upgrade
Prusa CORE One
Re: Bad 2nd Layer
Only JPG images seem to make it here. Even then, some with large META data spaces fail. And any print problem requires images to begin to help.
Re: Bad 2nd Layer
first layer too high?
and no I cant see the picture just guessing.
Re: Bad 2nd Layer (edited with images)
0.10 mm height
Amazon Basics PETG
First layer 220° C
Other layers 230° C
Looking at the first layer visible in the first image you seem to have an uneven bed level. The very top left looks perfect but as it moves to the right and down its starting to look as if you are too close to the bed and filament has started forming ridges by squeezing out the sides of the nozzle. Try either raising the nozzle a bit or reducing the filament flow by 5% or so.
Re: Bad 2nd Layer
Thank you for your idea. Your answer lead me to adjust the z level.
Prusa CORE One
