Am I trying to do something impossible?
Using textured sheet with PETG.
Trying to print out the test piece for the print in place Katana [ https://www.thingiverse.com/thing:3639693/files ]
I get maybe 4 MM up and the part pops off. Is it just too little surface area for the parts to reliably stick on the textured sheet? I tried adjusting my Z to below what I was comfortable with and still had issues of the part popping off.
RE: Am I trying to do something impossible?
Brim
Not impossible. You will need aupports and the right orientation or a brim.
Yeah trying to avoid using a brim just due to the nature of the print.
@dragon1291
Then focus on the orientation and z height.
@cwbullet
I mean, again with how the print is suppose to be, there's only one orientation to print it. I guess I could go for more squish but it just doesn't seem to want to stick even on a freshly cleaned sheet. Might try a lil dab of gluestick to see if that helps.
I talking in general. If support and adhesion fail, shift you orientation, Z, or add a brim. We suggested a brim and you don’t want to do that. That leaves the other 2. I print similar objects all the time without a brim. I squish it more. I will try to print it tonight - I am sure ti will pritn correctly for me. Check part is giving you trouble (of the 3).
