Adding self made support in a pause
I'd like to make bridges with a smooth and clean surface under.
Had anyone success adding it's own support object during a pause just before the bridging? I was thinking adding a PLA block just the right size with paper glue on the top so that it can be detached.
Is this is stupid idea?
RE: Adding self made support in a pause
Not a stupid idea at all. See https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/poor-mans-breakaway-supports-masking-tape-and-gluestick/#post-499954
Mk3S+,SL1S
I was thinking making special support parts and inserting it in a pause with glue, but this seems more simple.
If I understand right you let slicer print its support, then just add a thin tape layer with paper glue on top for improving finish?
So I tried with a full PLA part as a support. The underside finish improvement is really good. Issue was my support part was too strong and it was difficult to remove without damaging the part itself, the tape trick would solve this.
That's what I understand. I haven't done this myself. I was going to try it but having a flat surface on the underside of my sculpture didn't work artistically.
Mk3S+,SL1S
I posted my "reduce amount of supports" question before seeing this post. My intention was to use a piece of aluminum with tape on top but in view of your adhesion problem I may use a glue stick instead. Thanks
I have done this with wheel center caps with a raised design in the center, so printing them face down wouldn't work well..
My method was to find the height at which the bottom face of the top first gets bridged. This is easy to see in PrusaSlicer in the "Layers" view.
I then designed and printed a disc .2mm shorter and 5mm smaller in diameter than the opening inside the cap. As the caps themselves were made of ABS, I didn't want to use something with a lower temperature, so I printed the supports out of ASA. To reduce the tendency of the ABS to stick, I applied a thick coat of auto paste wax to the top of the supports. Added a Pause to the print, put in the supports and it seemed to work pretty well!
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-руÑÑки но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Thank you for the suggestions Keri. The information about clearance reduces my stress.
Raymond
Cool! If you wanted to keep the support from shifting about and possibly catching the nozzle, you could make one with a magnet embedded in the bottom. This would hold it firmly to the steel sheet. Done this way, I would have tried increasing the height a bit.
Good idea! I don't think the deck gets hot enough to demagnitize.
