A consistent defect at 10cm height (and 16cm height) at all prints
Page 2 / 2
christian
(@christian-4)
The belt tension
I printed the tension-meter as suggested by @diem, and both belts are bellow minimum. I guess I have to tighten the belts and test again 🙂
Publié : 30/09/2021 7:17 pm
christian
(@christian-4)
Problem solved
I tensioned the belts
Reprinted the cylinder, it was perfect
Reprinted one of the parts, it was perfect
Problem solved, thanks again!
Publié : 01/10/2021 10:10 pm
1 personnes ont aimé
Swiss_Cheese
(@swiss_cheese)
@christian-4
Thank goodness, or Diem in this case.
that was one of the easiest things it could have been.
Enjoy
Swiss_Cheese
The Filament Whisperer
Publié : 01/10/2021 10:41 pm
Problem solved,
Not so fast: problem mitigated.
The loose belts were permitting some other problem to manifest in the print, you have not fixed that issue, you've masked it.
I suggest it's time for a general maintenance tune up.
See: https://help.prusa3d.com/en/article/i3-printers-regular-maintenance_2072
Cheerio.
Publié : 01/10/2021 11:21 pm
christian
(@christian-4)
Problem mitigated
thanks @Diem, a suggestion could be that the printer had an option for showing a maintenance warning after evert x hours, just an idea.
Publié : 02/10/2021 5:42 am
This is just a user forum, for suggestions to reach Prusa devs go to Prusa's github.
Publié : 02/10/2021 9:33 am
Page 2 / 2
