3d Thread Measurements
muo
 muo
(@muo)
How do i measure threads for a part so i can insert a my own designed threads part in it, i know how to design threads in fusion-360 but i am not sure about best way to go about measuring threads that are standard and not standard?
do i use a caliper to measure the peak to peak distance and then hight and how many thread rings per inch/cm....???
do i need to measure other factors, the shape(profile) of the threads etc...or do i need to just keep trying and testing tweaking the profile until it fits?
what is the best way you guys have done it, do you have videos i can learn from found some but not sure if they are thorough
example (might be hard to get in there but still how can this be mesured)
https://www.homedepot.com/p/Westinghouse-2-3-16-in-Phenolic-Shade-Ring-for-Medium-Base-Phenolic-Sockets-7043500/206601202?mtc=Shopping-B-F_D27L-G-D27L-27_16_INTERIOR_LIGHTING-Generic-NA-Feed-PLA-NA-NA-INTERIOR_LIGHTING_GeneralInteriorLighting&cm_mmc=Shopping-B-F_D27L-G-D27L-27_16_INTERIOR_LIGHTING-Generic-NA-Feed-PLA-NA-NA-INTERIOR_LIGHTING_GeneralInteriorLighting-71700000038836110-58700004241533705-92700048704040391&gclid=EAIaIQobChMIrqP649jb5wIVE9bACh22owT1EAQYASABEgIEFfD_BwE&gclsrc=aw.ds
OR
this threads have different size and thicker more flat threads how can this be mesured
https://www.environmental-expert.com/products/lotus-flush-threaded-pvc-riser-screen-628077
or
or
This topic was modified 5 years ago 2 times by muo
Posted : 18/02/2020 6:32 pm
